schottky diode
schottky diode
what will i benefit from it? i ran my stock 27t motor without it but i installed ceramic capacitors 0.1uf..
am i doing fine?
thanks
am i doing fine?
thanks
oh i see, thanks xrayFK,
another question tho, do you got some pics of a schottky diode installed in a motor?
should i solder it together with the ESC wires touching the motor tabs? or should i only solder it in the motor tabs? its a non-polarized diode btw.
Here is an example if soldering the diode inline: http://groups.msn.com/RCZOMBIES/novakdiodemod.msnw
It's rc-zombies', hope he doesn't mind
edited
