Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
MUCH MORE Tire Sander and Motor Bearing Puller Remover >
Old 12-23-2013, 02:03 AM
Shop Owner
rcmart's Avatar
Thumbs up MUCH MORE Tire Sander and Motor Bearing Puller Remover
MUCH MORE Brushless Motor Bearing Puller Remover Ver.3 #MK-BRP3
This is the Muchmore Racing Power Truer 2 Rubber Tire Sander. The Power Truer 2 can be powered by a 12V power supply, as well as powered directly from a 2S LiPo battery! The Power Truer 2 is a quick and easy way to remove the seam from the center of a tire, without having to take 2-3 laps around the track. Simply attach the tire, turn it on and use a file or steel wool to resurface and re-scuff the tire for optimum performance. It's also great for removing track residue or "release agents" from tire surfaces!
Click here for more!
MUCH MORE Power Truer 2 12V Touring Rubber Tire Sander Black #MM-TSK2
This is the Muchmore Racing Brushless Motor Bearing Puller V3. This bearing tool is compatible with all brushless motors and ensures that the bearing is precisely aligned when mounted, making the job of removing or installing bearings effortless. The steel shaft features a high quality hard anodized aluminum handle for durability and long life.
rcmart is offline
