Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
Yeah Racing 2 In 1 Camber Gauge Tray, Front Knuckle Arm Set, Bearing Set >
Old 12-12-2013, 09:26 PM
Shop Owner
rcmart's Avatar
Red face Yeah Racing 2 In 1 Camber Gauge Tray, Front Knuckle Arm Set, Bearing Set
Yeah Racing 2 In 1 Aluminum Camber Gauge Tray 1.0 1.5 2 Angles For 1/10 YA-0330
The is a Yeah Racing Camber tray which is a combination of a Full functional camber gauge and small parts tray. This YR camber Tray will let you to measure camber angles at 1.0, 1.5, 2 which allows quick adjustment on the track-side and at the same time it could be use as a tray to keep all your screw and small parts in place. A must have item of your tool box.
*Photos for reference only.
Click here to know more!
Yeah Racing Aluminum Front Knuckle Arm Set For Axial SCX10 #SCX10-006BU
Yeah Racing made this front knuckle with premium material and precise CNC processing to ensure precise fit. This aluminum front knuckle is a direct replacement of the stock plastic parts, which makes your SCX10 even more unbreakable with smoother steering and control.
Yeah Racing RC Ball Bearing (2x5x2.5mm) 10pcs #YB6031MS/10
RC Ball bearings should always be your first upgrades, it reduces friction for less rolling resistance, and that means higher speed and longer the running times. RC Ball bearings hardly require maintenance and last a lot longer than stock Oilite bushings.
Yeah Racing RC Ball Bearings have the lowest resistance. They are manufactured by Aircraft quality stainless steel. Pre-lubricated with light protection oil (not grease) to ensure its excellent performance!
These high quality bearings outweigh the other low quality one:
  • Aircraft quality material
  • More durable
  • Higher precision
rcmart is offline
