Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
Tamiya Rear Upright 2.5 Degree, Gear Different Cup Joint & Steel Bevel Gear >
Old 11-21-2013, 06:50 PM
Shop Owner
rcmart's Avatar
Talking Tamiya Rear Upright 2.5 Degree, Gear Different Cup Joint & Steel Bevel Gear
Tamiya TT02 Aluminum Rear Upright 2.5 Degree #54549
Rear upright to be used in place of the plastic parts of the A11 standard. Aluminum cutting Made of high-precision, high-rigidity, yet change to 2.5 degrees from 0 degrees of the standard toe angle. Hold the slipping of the rear and realizing cornering stability. Bright blue anodized specification.
Click to know more!
Tamiya TB04 Gear Different Aluminum Cup Joint #54543
This is an aluminum cup joint set. It is designed to be used with the TB-04 touring car chassis. The set includes pin protectors (AKA drive shaft blades) to protect the joint cup and drive shaft from wear and tear. Installing these parts in place of those included in the kit will bring a weight savings of around 6.6g. Low friction anodized finish.
Click to know more!
Tamiya TB04 Steel Bevel Gears For Gear Differential Unit #54540
Tune up your TB-04 or TB-04 PRO chassis model with this steel bevel gear set. Steel bevel gears possess highly durable teeth, enabling them to be used in conjunction with high-powered motors. This set contains the bevel gears to fit out one gear differential.
Click to know more!
rcmart is offline
