-   rcMart.com Mega Online R/C Marketplace (https://www.rctech.net/forum/rcmart-com-mega-online-r-c-marketplace-79/)
-   -   YR Alu Conversion Kit Ultimate and Front Suspension Arm Set (https://www.rctech.net/forum/rcmart-com-mega-online-r-c-marketplace/767213-yr-alu-conversion-kit-ultimate-front-suspension-arm-set.html)
rcmart 10-24-2013 08:32 PM
The following 2 items are the lastest products developed by Yeah Racing! Take a look at the description in details!
*Yeah Racing Aluminum Conversion Kit Ultimate Version Blue For Tamiya TT-01/ TT-01E (FREE SHIP) #CK-TT01/EV2BU
http://www.rcmart.com/images/yeahrac...t01ev2bu-1.jpg
Yeah Racing TT01 conversion kit upgrade version will significantly improve the balance and speed of the Tamiya TT-01. Compared to the out of the box version, it improves TT01’s stability, allowing it to run smoother on different surfaces. Aluminum Main Drive Shaft replaces the standard molded plastic drive shaft for extra power handling; it also offers more predictable acceleration. The aluminum upper arm set is equipped with adjustable camber which enhances the response of Tamiya TT01 and allows for sharp turns. Different damper can also be selected to fit your own driving style. All in all, Yeah Racing TT01 conversion kit (upgrade version) includes everything you need to upgrade from the original TT01 to a competitive RC car.
Click to know more!!!
*Yeah Racing Aluminum Front Suspension Arm Set For 3Racing Sakura D3 CS Sport #SD3-001PK
http://www.rcmart.com/images/yeahracing-sd3-001pk-1.jpg
This is a Yeah Racing Aluminum Rear Suspension Arm Set For 3Racing Sakura D3 CS Sport. Yeah Racing carefully designed the suspension to be strong yet light-weighted for drifting. Flex has been minimized by precise CNC process, hence the weight shift will be smoother benefiting from the smoother suspension movements.
YR highly recommend to use this part with #SD3-002PK for the highest possible performance improvement.
