Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
Tamiya TT01 TT02 M05 Bodies, Motor, Gear, Shaft, Suspension Arms & other parts Stocke >
Old 10-21-2013, 12:05 AM
Shop Owner
rcmart's Avatar
Wink Tamiya TT01 TT02 M05 Bodies, Motor, Gear, Shaft, Suspension Arms & other parts Stocke
Tamiya TT01 TT02 M05 Bodies, Motor, Gear, Driveshaft, Suspension Arms & other parts Stocked!
Tamiya 1/10 Zakspeed Capri Wurth Body Parts Set for TT01 TT02 #51542
This is a spare body parts set that recreates the distinctive body of the Ford Zakspeed Turbo Capri Gr.5 Wurth-sponsored car. The body will fit any of Tamiya's 190mm width Touring car platforms such as the TT-01 and TT-02 that are built with the short wheelbase configuration. The polycarbonate body accurately captures the striking wide and low form of the Zakspeed car. Includes separate polycarbonate parts for light cases and rear wing.
Click HERE for more details~
Tamiya 1/10 Porsche 911 Carrera RSR Clear Body Parts Set for TT01 TT02 #51543
This is a clear polycarbonate body parts set of the Porsche 911 Carrera RSR race car. It is made out of 1mm thick polycarbonate. The set includes masking seals for the windows and a sticker set to replicate the Carrera RSR Team livery. Side mirror part is molded separately in black ABS plastic.
Tamiya 1/10 Monster Super Swift Clear Body Parts Set for M05 #51545
This is a clear polycarbonate body parts set of the GoPro Monster Sport Super Swift race car. It is made out of 1mm thick polycarbonate. The set includes masking seals for the windows and a sticker set to replicate the Go Pro Monster Sport Team livery. Includes separate parts to recreate rear wing, side mirrors and light cases. Set includes stickers to recreate the car's racy markings.
Tamiya TR Torque-Tuned Motor 33T for 1/14 RC Tractor Truck #56526
This motor is intended for use with 1/14 scale R/C Tractor Truck models. It prevents speed loss in the top gear of the 3-speed transmission, while allowing longer runs and easier maintenance. Low turn motor provides high torque, which gives the model more realistic and effective running in its top gear. Comes equipped with ball bearings. This motor has lower power consumption. Lower power consumption means longer driving times.
Tamiya G Parts Gears for XV-01 #51506
Tamiya Lightweight Front Direct Cup for TA06 TRF417 #54544
These are the latest option parts to be released for the TA06 4WD touring car chassis. This is a lightweight, newly-designed version of the front direct cup which was originally a part of #54304 TA06 Front Direct Coupling (39T). A swing shaft cap (blade) is also included to improve durability.
Tamiya Gear Differential Cross Shaft for TB04 #54533
The TB-04 touring car chassis platform is equipped with sealed oil-filled gear differentials. The cross shafts that are used are made of durable plastic. These Hop-Up-Option cross shafts are made of aluminum, which provide more precise gear movement. Made from aluminum, these parts are more durable than kit-standard parts and therefore provide more precise gear movement. Low-friction anodized surface coating makes for smooth gear motion. The two 2.8mm-diameter, 17mm shafts are used for a single gear differential.
Tamiya Front Upper Setting Suspension Arm Set for M05 #54529
Tamiya Flip-Flop 27cm For Men #67086
If you are a big fan of Tamiya, you should not miss this product! These Flip-Flops come in the Tamiya signature color of red and blue and with its big logo on top! Get a pair now!
Tamiya Carbon Body Mount Crossmember For M05 M06 #54530
Attaching this tough carbon-made body mount cross member to the body mounts on your M-chassis vehicle will provide your model with greater rigidity and fewer tendencies to lose stability during cornering. It has the additional effect of providing your model with crisper response to steering input.
Tamiya Aluminum steering Bridge for TB04 #54534
This is a high precision aluminum steering bridge that is designed to be used with the TB-04 chassis. It will increase steering response and it will help the cars performance when used in combination with high grip tires. The Hop-Up-Option parts replace the plastic kit standard bridge. Aluminum parts offer enhanced steering precision over kit-standard parts. Provides even more impressive steering effects when used in combination with high grip tires, or on high-grip surfaces. The part features a blue anodized finish.
Note: bearings are not included.
Tamiya Alumimum Gear Differential Unit Cup Joint for TA06 #54532
This cup joint set is made of aluminum and it's made to be used with the TA-06 gear differential unit. The standard cup joints are made of steel. The new aluminum cup joints also feature drive shaft pin protectors, also known as "blades" so the wear and tear to the cup joint is prolonged. Installing these parts in place of those included in the kit will bring a weight savings of around 7.6g. The set includes pin protectors to protect the joint cup and drive shaft from wear and tear. Can be used with TA06 front diff (39T) or rear diff (52T).
Tamiya 5mm Red Gear Differential O-Rings #42259
These are 5mm O-rings designed to be used in many of Tamiya’s oil-filled sealed gear differentials like the ones’ found on the TA-05 option sealed gear set as well as the included sets found on the TA-06, XV-01 and TRF417 series of cars. The inner diameter of the O-ring is slightly smaller than the standard kit black O-ring. The smaller inner diameter O-ring better prevents oil from leaking out of the gear differential.
Tamiya RC Damper X-Ring 70 Durometer 8pcs #42215
These Damper X-rings have X-shaped cross-sections and offer increased oil sealing effect compared to standard O-rings with circular cross-sections. Made from special silicone material, these X-rings also maintain their shape, and therefore their sealing ability, for a longer period of time. This makes them ideal for use with Aeration Dampers such as Item #42198 Buggy HL Aeration Damper Set and Item #54028 Buggy Aeration Oil Filled Damper Set.
rcmart is offline
