Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
Tamiya TB-04 Pro Chassis Kit #84339 & TT02 Ford Zakspeed Turbo Capri Wurth #58578 >
Old 09-15-2013, 10:49 PM
Shop Owner
rcmart's Avatar
Talking Tamiya TB-04 Pro Chassis Kit #84339 & TT02 Ford Zakspeed Turbo Capri Wurth #58578
Tamiya Latest TB-04 and TT02 Now in rcMart.
Tamiya 1/10 TB-04 Pro Chassis Kit EP #84339
Tamiya 1/10 TT02 Ford Zakspeed Turbo Capri Wurth w/ESC EP On Road #58578
+ YouTube Video
  • Special feature 1 : Low center of gravity design
  • Special feature 2 : Newly-designed transmission case helps to provide increased stability during acceleration
  • Special feature 3 : New differential gear features 40T ring gears and 16T bevel gears
  • Special feature 4 : Uses a long steering tie-rod system refined on the TRF417 chassis.
  • Special feature 5 : Newly-designed battery holder provides simple and secure attachment
  • Special feature 6 : Racers can choose between inboard and outboard front suspension.
  • Special feature 7 : Features a new motor guard to protect the motor in impacts.
  • Special feature 8 : Employs short oil dampers for touring cars to enable lower ground clearance, while maintaining stroke
Click HERE to Find Out More~
  • Special feature 1 : Easy to build entry level kit
  • Special feature 2 : Includes window masking seal for easy painting
  • Special feature 3 : Highly detailed body with vinyl stickers
  • Special feature 4 : Symetrical suspension components
  • Special feature 5 : Beveled main chassis for improved cornering clearance
  • Special feature 6 : Brake disc shaped wheel hubs
  • Special feature 7 : Compatible with 380-size motors
  • Special feature 8 : Battery compartment compatible with square shaped batteries
  • Special feature 9 : Separate parts are included to depict light cases and rear wing
  • Special feature 10 : Includes RS-540 Torque-Tuned Motor
Click HERE to Find out More~
rcmart is offline
