Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
FreeShip Hobbywing EZRUN Waterproof 120A Brushless ESC w/ YR Sensored 8.5T Motor >
Old 07-23-2013, 11:45 PM
Shop Owner
rcmart's Avatar
Default FreeShip Hobbywing EZRUN Waterproof 120A Brushless ESC w/ YR Sensored 8.5T Motor
Hobbywing EZRUN WP SC8 Waterproof 120A Brushless ESC w/ YR Sensored 8.5T Brushless Motor (FREE SHIP) #CB0626
Includes:
  • Hobbywing EZRUN WP SC8 Waterproof 120A Brushless ESC SCT SPORT #EZRUN-WP-SC8
  • Yeah Racing HACKMOTO EVO Modified 540 Sensored Brushless Motor 8.5T 4200kv For 1:10 Onroad & Offroad RC Car #MT-0007
Feature:
  • For: 1/10 4WD SCT / 1/8 2WD and 4WD Buggy / SCT (Include TRAXXAS 1/10 SCT);
  • Design: Sensorless-Based
  • Completely water-proof and dust-proof
  • Powerful built-in switching mode BEC
  • Excellent start-up, acceleration and linearity features
  • Plenty of programmable items, suitable for various of chassis's, tires and racing tracks
  • Electric brake function, also compatible with mechanical disc-brake system
  • Multiple protection features: Low voltage cut-off protection / Over-heat protection / Throttle signal loss protection
  • Internal timing can be changed easily to make the ESC suitable for various of motors
  • Easily programmed with the SET button, LED Program Box, Multifunction LCD Program Box and USB Link Software
  • Special program port for easily setting the ESC
  • ESC firmware can be updated through the USB adapter in the LCD Program Box
  • Mounting stand for installing the ESC on chassis easily and firmly
Specification:
  • Output: Continuous 120A / burst 760A
  • Input: 6-12 cells NiMH/NiCd or 2-4S Lipo
  • BEC Output: 6V/3A (Switching mode) [* Note #1]
  • Resistance: 0.0004 Ohm
  • Motor Supported: Sensorless Brushless Motor
  • Suitable Brushless Motor:
  • With 6 cells NiMH/NiCd or 2S Lipo: KV≤6000
  • With 7-9 cells NiMH/NiCd or 3S Lipo: KV≤4000
  • With 10-12 cells NiMH/NiCd or 4S Lipo: KV≤3000
  • Size: 59mm(L) * 38mm(W) * 34mm(H)
  • Weight: 113g
* Note #1: The cooling fan of EZRUN-WP-SC8 is powered by the built-in BEC.
Feature:
  • Adjustable timing
  • Hand-wound for maximum copper fill
  • High purity copper windings to maximize conductivity
  • Sensor-based for excellent torque and low speed drive-ability
  • CNC machined heat sink
  • Powerful sintered neodymium magnet
  • Precision engineered for maximum energy conversion
  • Super smooth start up
  • All motor is factory tested to ensure proper performance
Specification:
  • Design: Sensored
  • Size: 540
  • Turns: 8.5T
  • Input voltage: Li-Po 1-2S
  • KV (RPM/volt): 4200
  • Shaft Diam: 3.17
  • Build-in Fan: Yes
Click HERE for more information~
rcmart is offline
