Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
TRF201 TRF511 TRF502X DB01 & DB02 Buggy Suspension Upgrade Parts >
Old 07-22-2013, 12:06 AM
Shop Owner
rcmart's Avatar
Default TRF201 TRF511 TRF502X DB01 & DB02 Buggy Suspension Upgrade Parts
Tamiya Buggy Big Bore Damper Front - Aeration Type (2pcs) #54504
These dampers feature all-new parts, and their main feature is the cylinder: it has an inner diameter of 12mm, 2mm wider than that on the standard Buggy Aeration Damper. As a result, it can hold 40% more oil and that means less wear and tear on the vehicle! A number of option parts have been released to increase setup options to these dampers such as different size pistons.
Click HERE for more Info~
Tamiya Buggy Big Bore Damper Rear - Aeration Type (2pcs) #54505
Tamiya Big Bore Damper Spring Set - Aeration Type - Front (4WD) #54506
These option part springs are available to further upgrade items 54504/54505 Buggy Big Bore Aeration Dampers. 3 varieties of hardness are included to allow racers to tailor their car’s suspension to the unique challenges of each course.
Tamiya Big Bore Damper Spring Set - Aeration Type - Rear #54508
Tamiya Big Bore Damper Spring Set - Aeration Type - Front (2WD) #54507
Tamiya Big Bore Damper Rod guide - Aeration Type (4pcs) #51538
Tamiya Big Bore Damper Pistion - Aeration Type - Blank (4pcs) #54509
Take complete control of the details in your suspension! These blank pistons allow the owner to make as many holes of whatever size they like, in order to get the suspension performance they want. Compatible with items 54504/54505 Buggy Big Bore Aeration Dampers.
Tamiya Big Bore Damper Pistion - Aeration Type 1.6mm x 2 (4pcs) #51539
This parts set allows fine adjustment of the performance of Items 54504/54505 Buggy Big Bore Aeration Dampers according to track conditions and machine characteristics desired. 2 additional holes may also be made in the piston using a pin vise if desired.
Tamiya Big Bore Damper Pistion - Aeration Type 1.7mm x 2 (4pcs) #51540
rcmart is offline
