Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
XPERT Servos, SKYRC Charger Battery Motor RPM Servo Tester, KO PROPO EX-1 Ver.3 >
Old 07-08-2013, 06:59 PM
Shop Owner
rcmart's Avatar
Default XPERT Servos, SKYRC Charger Battery Motor RPM Servo Tester, KO PROPO EX-1 Ver.3
Looking for servos? XPERT could be a nice choice!
XPERT HV Brushless Servo High Voltage 8.4v 16.24kg 0.097 sec For 1/8 1/10 #SI-4501 FREE SHIPPING
XPERT LV Brushless Servo Low Voltage 6.6v 11.34kg 0.08 sec For 1/8 1/10 #SI-3401 FREE SHIPPING
XPERT Low-Profile BRUSHLESS SERVO 1/8 1/10 6.6v 12kg 0.076sec #PI-3401 LV FREE SHIPPING
Three choice available!
SKYRC T6200 Professional AC DC Balance Charger Discharger Battery Motor RPM Servo Tester #SK-100072-01
Item no.: SK-100072-01
KO PROPO EX-1 Ver.3 KIY Concept w/ FHSS 2.4GHz Receiver KR-411FH #80536
This is the KO Propo EX-1 KIY V3 Concept 2.4GHz FHSS Radio System, with an included KR-411FH Micro Receiver. The Ver.3 EX-1 KIY uses the same Ver.2 software in the Master Unit, but includes the redesigned ‘Expert Grip Unit’. This grip unit has updated grip pads that provide a different fulcrum point on the handle and an updated trigger with a redesigned trigger stroke.
The KO PROPO Kustomize It Yourself (K.I.Y.) is an interchangeable transmitter that brings simplicity to customizing and upgrading within a modular system. The transmitter is composed of 3 modular units: Steering, Throttle and Master units. The three separate modular units can be easily put together, no screws required. Just push the safety lock of the joint, pull the lever and pull or push to insert or remove the modular unit. It's that simple! You can use the K.I.Y. to unlock your next system and bring more enjoyment to your hobby.
As optional parts and items become available you can add to your existing system without worrying about purchasing an entirely new transmitter for you to use. One of the many bonuses of the KIY concept.
Features:
  • Expert Grip
  • High performance CPU & 2.7inch LCD
  • Quick SetUp Function
  • EX-1 Direct Button
  • EX-1 2.4GHz FHSS
  • EX-1 7 LED color
  • 629g Super light weight
  • 40 Model memory
Specifications:
  • Transmitter: KT-411H
  • Master Unit: 10520 FHSS Ver.2
  • Steering Unt: 10506 Steering Unit EX-1
  • Grip Unit: 10526 Expert Grip
  • Receiver: KR-411FH
  • Operating system: steering wheel & throttle trigger
  • Number of channels: 4
  • Transmit frequency band: 2.4GHz
  • Nutral pulse: 1.5msec
  • Power source: RO3/AAA/UM4 battery x 4, or 4 cell battery pack
  • Current consumption: less than 140mA
Include:
  • KO PROPO EX-1 Ver.3 (1 Set)
  • FHSS 2.4GHz Receiver #KR-411FH (1 pc)
  • CD Rom (1 pc)
  • Manual (1 pc)
  • Sticker (1 pc)
Item no.: 80536
rcmart is offline
