SP ESC & YR Motor 10.5T Combo, VBC Damper & Joint Drvie Axle, & G.T XDRIVE Charger
Speed Passion Reventon Pro Brushless ESC w/ YR Sensored Motor 10.5T for 1/10 1/12 RC Racing #Champion 10.5T
Includes:
Item No.: Champion 10.5T
VBC Racing Aluminum Damper Retainer for WildFire/FFTwelve/Flash04 #A-03-VBC-0086
Item No.: A-03-VBC-0086
VBC Racing Two Piece Joint Drive Axle Set For Tamiya TRF416 TRF417 #D-05-VBC-0072
The Two-Piece Joint Drive Axle Set featured revolutionary design makes it one of the widest turning angle in the market. Made with heavy duty hardened steel that can withhold heavy impact and with precise steering.
Item no.: D-05-VBC-0072
G.T. Power XDRIVE-607 Balance Charger Discharger For RC Battery LiPo NiMh #X-DRIVE 607
Includes:
- Speed Passion Reventon Pro Brushless ESC (Metal Black Silver) [2 Cell] #SP000222
- Yeah Racing Modified 540 Sensored Brushless Motor 10.5T 3600kv
- For: NiCd / NiMH / LiPo / Lilon / Life / Lead-Acid cells
- Cell Count: 1-15 Nicd/Nimh cells 1-6 Lipo/Lilon/LiFe cells 1-10 Lead-Acid cells (2v-20v)
- Operating Voltage Range: DC 11-18 Volt
- Charge power: Max. 320 Watt(4x80W)
- Discharge power: Max. 20 Watt(4x5W)
- Charge Current rate: 0.1-7.0A for each pc
- Discharge Current rate: 0.1-1.0A for each pc
- Current Drain for balancing Lithium: 300A
10.5 t, balancer, bargain, brushless, charger, combo, damper, deal, discharger, drive axle, esc, g.t power, joint drive, lipo, motor, nimh, special, speed passion, teah racing, vbc, yeah
