Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
Traxxas Slash, Rustler, Stampede, Bandit, Power Cell LiPo Included! >
Old 11-11-2012, 07:44 PM
Shop Owner
rcmart's Avatar
Post Traxxas Slash, Rustler, Stampede, Bandit, Power Cell LiPo Included!
Slash VXL, Rustler VXL, Stampede VXL, Bandit VXL
Traxxas' Top-Performing VXL Models, now available with Power Cell LiPo Battery!
Designed from the start for high-voltage, high-capacity LiPo packs, Traxxas' VXL brushless models now include genuine Traxxas Power Cell LiPo batteries—the only LiPos certified to deliver the full performance potential of Traxxas' VXL brushless models. The Rustler, Bandit, and Stampede VXL each include a 3300mAh Power Cell pack; Slash VXL includes a 4200mAh battery.
Each LiPo-equipped model arrives with Low Voltage Detection activated to assure maximum battery life and prevent over-discharging. Charging care is just as important to LiPo life and performance, so a 2-Cell / 3-Cell LiPo Balance charger is also included. Just plug the battery’s balance plug into the charger and you’re on the way to another run—no programming or settings required. Every time the pack is charged, the cells are charged individually to precisely balance voltage for optimum performance, run time, and cycle life. Experience the ultimate in electric horsepower with the only models designed for LiPo power from the start, and genuine Power Cell LiPo technology on board.
Rustler VXL, Bandit VXL, and Stampede VXL each include one 3300mAh battery. Slash VXL includes one 4200mAh battery
Factory-Fresh Power Cell Performance
To assure you experience the full capacity, voltage, and performance we build into every Power Cell LiPo pack, the LiPo battery is supplied separately at the time of purchase. This makes certain you receive a pack that is “factory fresh.” You can even upgrade to a different Power Cell LiPo to suit your preference for capacity and voltage. See your participating hobby dealer for all the Traxxas Power Cell battery upgrade options.
With Traxxas, Power Cell LiPo performance is a promise.
  • High-Current Connector
  • The Velineon Brushless Power System and Power Cell LiPo battery feature High-Current Connectors to make sure each VXL model achieves maximum Power Cell performance. The Traxxas Connector effortlessly funnels the battery's total power to keep things running cool and at full capacity.
  • TQi 2.4GHz Transmitter
  • The sleek TQi transmitter delivers long-range control and pro-level tuning features. Install the optional Docking Base and TQi accepts your iPhone or iPod touch for high-res, touchscreen control of all the TQi’s settings and adjustments via the exclusive Traxxas Link application.
  • Low Voltage Detection
  • Traxxas LiPo-equipped models arrive with Low Voltage Detection activated to protect against over-discharging and assure maximum cycle life. When the battery’s voltage drops to the minimum threshold, the speed control reduces throttle to indicate it’s time to recharge.
VXL Models Feature:
  • NEW Power Cell 3300mAh LiPo Battery with Bandit VXL, Rustler VXL, and Stampede VXL
  • NEW Power Cell 4200mAh LiPo Battery Included with Slash VXL
  • NEW 2-Cell / 3-Cell LiPo Balance Charger
  • TQi 2.4GHz transmitter, Docking Base compatible
  • 5-channel receiver with Fail Safe
  • Velineon Extreme Brushless Power System
  • Waterproof electronics
  • High-Torque steering servo
  • Steel-gear Magnum 272 transmission
  • Oil-filled Ultra Shocks™
  • Torque-Control™ slipper clutch
  • Rubber-sealed ball bearings
rcmart is offline
