Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
G. T. Power IC Controlled Tire Warmers - New!! >
Old 04-03-2011, 09:57 PM
Shop Owner
rcmart's Avatar
Default G. T. Power IC Controlled Tire Warmers - New!!
G. T. Power (#GTP-W) IC Controlled Tire Warmers - New!! http://www.rcmart.com/catalog/rc-tir...s-p-33443.html
Feature:
# For 1/10 tourning car / 1/10 M CAR / MAYBE 1/10 offroad car
# Celsius / Fahrenheit selectable display
# Minimum temperature
# 8 different beep tones
# Adjustable black light and contrast
# Front & Rear interdentally temperature setting
# Temperature controlled by micro processor
# Car stand design
# Various alarm system like to disconnection, delay, low input voltage etc.
# Can use Muchmore cups with foam inserts for 1/10 scale tires
rcmart is offline
Old 05-20-2011, 01:16 AM
Geberit's Avatar
Has anyone tried this thig? It,s cheap and if it works
Regards
Geberit is offline
Old 06-05-2011, 12:06 PM
roger999's Avatar
Regards
So, anyone tried it?
roger999 is offline
Old 06-27-2011, 05:24 AM
Its just awesome and its incredibly light!
++SGS is offline
Old 07-15-2011, 01:06 AM
Hoggy's Avatar
Trader Rating: 26 (100%+)
Can you put a battery in it like the muchmore tyre warmers or you have to run a power supply
Hoggy is offline
Old 07-16-2011, 04:23 PM
drsfly's Avatar
Default correct cups???
Rc Mart,
Which are the correct Much more cups to use. I looked and saw the ones for the ctw--L but the plug in is not the same. Please advise the correct part number because itr will not plug in as stated in the GT ad if it is not the correct one.
Other than that it seems to work well so far.\\
Darrald
drsfly is offline
Old 11-23-2011, 06:42 AM
evostyle's Avatar
Trader Rating: 102 (98%+)
Does this work with the muchmore warming cups?
evostyle is offline
Old 12-12-2011, 11:56 AM
well does it ?
Burney is offline
Old 01-03-2012, 11:58 PM
Shop Owner
rcmart's Avatar
Thx for enquiry. This products does not work with Muchmore warming cup. It only work with the one made by themselves.
rcmart is offline
Old 01-04-2012, 01:09 AM
evostyle's Avatar
Thanks! I ended up buying a set and the wrap style warmers work just fine.
evostyle is offline
Old 01-20-2012, 06:34 PM
bukil's Avatar
Trader Rating: 39 (100%+)
Muchmore tire warmer cups work. I tried the ones that came with this.
bukil is offline
Old 01-05-2014, 08:31 AM
dvsstrike's Avatar
used these warmers this weekend and they were great. I like the fact that I can use them on f1 tires as well.
dvsstrike is offline
