Go Back  R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
New and Restocked Traxxas Hop Ups @ rcMart!! >
Old 03-21-2011, 06:49 PM
Shop Owner
rcmart's Avatar
Default New and Restocked Traxxas Hop Ups @ rcMart!!
Great News for Traxxas Fans!! We have prepared lots of new and restocked Traxxas Hop Ups for you, now just check it out: http://www.rcmart.com/catalog/hopup-...c-595_739.html .
The below is the new and restocked Traxxas Hop Ups List:
New Items:
Traxxas (#2542) Countersunk Machine Hex Drive Screws 4×12mm
Traxxas (#2554) 3×6mm Cap Hex Screws
Traxxas (#2640) 44mm Chrome Suspension Pins with Clip for Nitro Stampede & Rustler
Traxxas (#2656) Shock Shafts For Traxxas shocks (hard chrome) (xx-long)
Traxxas (#2667) Big Bore Aluminum Shock Caps
Traxxas (#2742) Rod Ends (long) (6) and Hollow Ball Connectores (6)
Traxxas (#3060) Connector (male/female)
Traxxas (#3061) Adaptor, Traxxas Connector Male to Molex Female
Traxxas (#3062) Adaptor, Traxxas Connector Female to Molex Male
Traxxas (#3070) Traxxas Connector (male) (2 Pcs)
Traxxas (#3159) Hex Screws 3×10mm For Nitro Hawk
Traxxas (#3195) Top Drive Gear
And more……
Traxxas (#3232) SD Long Glow Plug
Traxxas (#3351) Brushless Velineon 3500 Motor
Traxxas (#3352) Velineon 3500 Rebuild Kit
Traxxas (#3353) Velineon 3500 Rotor for Bandit, Stampede & Rustler
Traxxas (#3371) Brushless Velineon 380 Motor
Traxxas (#3639) Shock Tower (Front) For Stampede
Traxxas (#3640) Suspension Screw Pins Set For Rustler, Stampede, Bandit
Traxxas (#3643) Turnbuckles & Camber Link For the Bandit, Rustler VXLStampede VXL
Traxxas (#3644) Turnbuckles & Camber Link For Stampede ,Rustler VXL
Traxxas (#3654) Hex Wheel Hubs Set for Rustler & Stampede
Traxxas (#3669) Talon 2.8 Front Tires & Wheels For Stampede
Traxxas (#3678) Complete Wheelie bar assembly For Electric Stampede, Rustler, Bandit
Traxxas (#3691) Gearbox L&R W/Idler Gear (BK)
Traxxas (#3696) Idler Gear
Traxxas (#3736) Steering blocks, left & right (2)
Traxxas (#3743) Steering Bellcranks & Draglinks for Rustler & Stampede
Traxxas (#3744) Servo Saver w/ Adaprors
Traxxas (#3762) Black Shocks Stampede (XXL)
Traxxas (#3793) Input Shaft (slipper shaft) w/ spring pin
Traxxas (#3921) Lower Chassis Braces (BK) for E-Maxx
Traxxas (#3937) Screws 4×12mm Button Head For Revo
Traxxas (#4317) Rear Shock Tower 4-Tec For Nitro and Electric 4-Tec Four Wheel Drive On-Road Sedan
Traxxas (#4336) Steering Blocks For Nitro ,Electric Powered 4-Tec Touring Cars
Traxxas (#4352) Rear Hub Carriers 1.5 Degree For Traxxas Electric , Nitro 4-TEC touring cars
Traxxas (#4628) Yokes/Screws For Rustler, Stampede
Traxxas (#4831) Front Susp Arms
Traxxas (#4850) Rear Suspension Arms Left/Right For Nitro 4-Tec 3.3 RTR
Traxxas (#4851) Drive Shafts Telescopic For Nitro 4-Tec 3.3 RTR
Traxxas (#4853) Stub Axles For Nitro 4-Tec 3.3 RTR
Traxxas (#4863) Mid Drive Belt For Nitro 4-Tec 3.3
Traxxas (#4864) Front Drive Belt 4.5mm For Nitro 4-Tec 3.3
Traxxas (#4865) Rear Drive Belt 6.0mm For Nitro 4-Tec 3.3
Traxxas (#4885) Spur Gear 1st 41T Standard For Nitro 4-Tec 3.3 RTR
Traxxas (#4886) Spur Gear 2nd 37T Standard For Nitro 4-Tec 3.3 RTR
Traxxas (#4887) Spur Gear 1st 45T Optional For Nitro 4-Tec 3.3 RTR
Traxxas (#4888) Spur Gear 41T Optional For Nitro 4-Tec 3.3 RTR
Traxxas (#4895) Pulleys 20 Groove Middle For Nitro 4-Tec 3.3 RTR
Traxxas (#5337) Skid Plate Set For Revo
Traxxas (#5338) Toe Link 5.0mm
Traxxas (#5551X) Steel Drive Shaft Kit For Jato
Traxxas (#5591) Gear Box Halves For Jato
Traxxas (#6873R) Tire & Wheel Assembly Glued Chrome Red For Slash 4×4
Traxxas (#7158) Rocker Arm Set For E-Revo / Slash VXL 4WD
Restocked Items:
Traxxas (#1633) E-Clips, C-Clips, and Body Clips for Traxxas Cars and Trucks
Traxxas (#1654) Hex Wheel Hubs & Stub Axle Pins
Traxxas (#1664T) Shock Shafts (Titanium Nitride Coated) (L)
Traxxas (#1666) Silicone Shock Oil (30wt)
Traxxas (#1765) Rubber Diaphragms for oil damper (4pcs)
Traxxas (#1834) Body Clips
Traxxas (#1918) Alloy Motor Pinion Gear (48P 18T)
Traxxas (#1942) Rod Ends (16 long & 4 short) / Hollow Balls Connectors (18)
Traxxas (#1951) Half Shafts, Long Truck
Traxxas (#1952) Stub Axle Housings (Rear)
Traxxas (#1985) Fiber Washers 5×8mm
Traxxas (#2082) Gear Set for VXL Micro Waterproof Servo
Traxxas (#2362) Shock Rebuild Kit
Traxxas (#2381X) Main Diff with Steel Ring Gear
Traxxas (#2382) Planet Gears & Shafts /Sun Gears & Alignment
Traxxas (#2423) Pinion Gear 23T 48P w/Set Screw
Traxxas (#2431) Pinion Gear 31T 48P w/Set Screw
Traxxas (#2530A) Bulkhead (Front) (GY)
Traxxas (#2532) Tie Bar, Fiberglass
Traxxas (#2656T) Shock Shafts Titanium (XX-Long)
Traxxas (#2742X) Rod Ends (Short) (6) and Hollow Balls (6)
Traxxas (#2753X) Rear Stub Axles
Traxxas (#2765T) Shock Shafts (Hardened Steel and Titanium Nitride) (x-long)
Traxxas (#3139X) Aluminum Toe Links for Rustler & Slash
Traxxas (#3232X) Super Duty Long Glow Plug For Revo
Traxxas (#3355X) VXL-3S Electronic Speed Control
Traxxas (#3632X) Caster Blocks (30-degree)
Traxxas (#3655X) Left and Right Suspension Arms for the Traxxas Slash 4×4
Traxxas (#3691A) Gearbox L&R W/Idler Gear
Traxxas (#3741X) Aluminum Turnbuckle Set Red for Rustler & Stampede
Traxxas (#3743A) Blue-Anodized Aluminum Steering Bellcranks for Slash
Traxxas (#3767X) Aluminum Shocks Caps
Traxxas (#3922A) Chassis For E-MAXX (Long Wheelbase)
Traxxas (#3930) Bulkhead Cross Braces for the Traxxas E-Maxx
Traxxas (#3934) Body Clips for MAXX Series
Traxxas (#3941R) Tubes™ Steering Drag Link
Traxxas (#3942) Pinion Gear 12T-32P
Traxxas (#3943) Pinion Gear 13T-32P
Traxxas (#3944) Pinion Gear 14T-32P
Traxxas (#3946) Pinion Gear 16T-32P
Traxxas (#3948) Pinion Gear 18T-32P
Traxxas (#3949) Pinion Gear 19T-32P
Traxxas (#3950) Pinion Gear 20T-32P
Traxxas (#3952) Pinion Gear 22T-32P
Traxxas (#3953) Spur Gear 1.0P 36T For Revo / Slayer
Traxxas (#3954) 38T Spur Gear
Traxxas (#3956) Spur Gear 54T
Traxxas (#3956R) 54T 32P Spur Gear for Slash 4×4
Traxxas (#3957) 56 Tooth Spur Gear for Traxxas Nitro Jato Stadium Truck
Traxxas (#3958) Spur Gear 58T
Traxxas (#3960) Spur Gear 65T
Traxxas (#3961) Spur Gear 0.8P 68-Tooth For Revo / E-Maxx
Traxxas (#3969) Transmission Output Shaft
Traxxas (#3991X) Gearbox Halves
Traxxas (#3996X) Idler Gear (20T)
Traxxas (#4118) Clutch Bell Steel 18T for 1:10 Nitro Vehicles
Traxxas (#4122) Clutch Bell Steel 22T for 1:10th Nitro Vehicles
Traxxas (#4124) Clutch Bell Steel 24T for Traxxas 1:10 Nitro Vehicles
Traxxas (#4142X) Flywheel (Large, Knurled For Use w/Starter Boxes)
Traxxas (#4146) Clutch Shoes & Spring for Nitro Stampede & Rustler
Traxxas (#4146X) Clutch Shoes & Spring
Traxxas (#4579) EZ-Start Quick Connector
Traxxas (#4611) Ball Bearing 5×11x4mm for T-Maxx & Revo
Traxxas (#4628R) Differential Output Yokes
Traxxas (#4628X) Differential Output Yokes & Hardened Steel
Traxxas (#4686) Original Spur Gear (48P 86T)
Traxxas (#4690) Original Spur Gear (48P 90T)
Traxxas (#4728) Pinion Gear (48P 28T)
Traxxas (#4897) 4mm Grubs Screws
Traxxas (#4917R) Shock Tower
Traxxas (#4929R) Bulkheads (L & R) Rear
Traxxas (#4930R) Bulkheads (L & R) Front for T-Maxx 3.3
Traxxas (#4937A) Skidplate Front Plastic / Stainless Steel Plate (Grey) For Traxxas T-Maxx 3.3/E-Maxx
Traxxas (#4938A) Skidplate Rear Plastic / Stainless Steel Plate (Grey) For Traxxas T-Maxx 3.3
Traxxas (#4945) Steering Bellceanks, Servo Saver, Saver Spring, Spring Retainer For Traxxas E-Maxx
Traxxas (#4951R) Center Driveshsfts for E-MAXX
Traxxas (#4962) Shocks Big Bore
Traxxas (#4973) 3.8 inch Tires for Traxxas Revo and Maxx Series
Traxxas (#4975) Wheelie bar
Traxxas (#5131R) Suspension Arms Upper (2) Fit For All Maxx Series
Traxxas (#5132R) Suspension Arms Lower (2) Fit For All Maxx Series
Traxxas (#5136X) Differential Oil Kit
Traxxas (#5141R) Tubes™ Toe Links
Traxxas (#5143) Turnbuckles, Toe Links (5.0mm Steel) Rear For Traxxas T-Maxx 3.3
Traxxas (#5143R) Toe Links
Traxxas (#5145) Screw Pin 4×15mm For Slayer / Revo
Traxxas (#5148) White Lithium Grease
Traxxas (#5161) Suspension Screw Pin Set Hardened Steel (hex drive)
Traxxas (#5170) Starter & Recoil
Traxxas (#5172) Split Spoke 3.8″ Satin Finish Wheels for Traxxas Revo, T-Maxx and E-Maxx
Traxxas (#5172R) Split Spoke 3.8
Traxxas (#5172X) Split-Spoke 3.8 Chrome Wheels
Traxxas (#5186) Mounted Wheelie Bar Tires/Wheels
Traxxas (#5186A) Mounted Wheelie Bar Tires/Wheels
Traxxas (#5211R) Roller Clutch T-Maxx 2.5
Traxxas (#5224) Connecting Rod (TRX 2.5, 2.5R, 3.3)
Traxxas (#5245) Pipe Coupler / Exhaust Deflecter & Ties
Traxxas (#5262) Air Filter & Pre-Filter Insert for Revo, Slayer & T-Maxx
Traxxas (#5266) Air Filter Body for Revo3.3/Slayer/Slayer Pro 4×4
Traxxas (#5280) Control Box
Traxxas (#5290) Traxxas Piston/Sleeve for TRX 3.3
Traxxas (#5314) Front & Rear Body Mounts w/Posts & Pins For Revo
Traxxas (#5315) Steering Servo Guards
Traxxas (#5318X) Push Rod
Traxxas (#5329) Bulkhead Rear (L & R Halves)
Traxxas (#5331) Suspension Arm Right Front U/L
Traxxas (#5332) Suspension Arms Left Front U/L
Traxxas (#5333) Suspension Arm Upper (1)
Traxxas (#5333R) Suspension Arm Set
Traxxas (#5334) Axle Carriers (L & R)
Traxxas (#5334R) Axle Carriers Left & Right/Bearing Adapters
Traxxas (#5338A) Revo Toe Links (Tubes 7075-T6)
Traxxas (#5338R) Revo Toe Links (Tubes 7075-T6)
Traxxas (#5340) Aluminum Exhaust Header Silver Anodized For Revo
Traxxas (#5344X) Heavy Duty Servo Saver Spring For Revo / Slayer
Traxxas (#5347) Rod Ends w/Hollow Balls Large Revo
Traxxas (#5348) Rod Ends
Traxxas (#5351) Slipper Pressure Plate & Hub For Revo
Traxxas (#5352X) Slipper Clutch Rebuild Kit for Revo/Maxx
Traxxas (#5353) Wheel Nuts Splined 17mm
Traxxas (#5353X) Wheel Hubs
Traxxas (#5360) Engine Mount for the Traxxas Revo
Traxxas (#5360X) Big Block Installation Kit
Traxxas (#5372A) Gemini Chrome 3.8 for Traxxas Revo
Traxxas (#5373) Hurricane 3.8 Wheels
Traxxas (#5374X) Talon Tires mounted on Gemini Black Chrome Wheels for Traxxas Maxx and Revo Vehicles
Traxxas (#5378X) Pivot Ball Caps / Dust Boots & Plugs Set
Traxxas (#5379X) Differential Ring Gear & Pinion Gear
Traxxas (#5380) Differential Housing for Revo
Traxxas (#5381) Differential Rebuild Kit
Traxxas (#5381X) Spool, Differential (Eliminates Differential Use Off-Road Only) Traxxas Revo
Traxxas (#5382X) Gear Set Diff For Revo / E-Maxx / Slayer
Traxxas (#5383) Gear Set, 2-Speed Close Ratio (2nd Speed Gear 40T, 13T-16T Input Gears, Hardware) For Traxxas Revo
Traxxas (#5385) Gear Set, 2-Speed Standard Ratio (2nd Speed Gear 39T, 13T-17T Input Gears Hardware) For Traxxas Revo
Traxxas (#5395) Replacement FWD/REV Output Gears for the Traxxas Nitro Revo Monster Truck
Traxxas (#5395x) Reverse Installation Kit
Traxxas (#5411) Revo Wing Mount
Traxxas (#5412) Revo wing
Traxxas (#5445) Shock Spring (GTR) (6.4 rate)
Traxxas (#5450) Half Shaft Set L/R Maxx/Revo
Traxxas (#5451R) Driveshafts
Traxxas (#5451X) Drive Shaft Assembly
Traxxas (#5452) U-Joints Drive Shaft
Traxxas (#5453) Stub Axle Yokes with Pins
Traxxas (#5455) Center Front & Rear Half Shafts For Revo
Traxxas (#5456) Half Shafts Center For Revo / Slayer
Traxxas (#5458X) Yokes, Differential and Transmission
Traxxas (#5459) Driveshaft Boots
Traxxas (#5462) GTR Shock Rebuild Kit
Traxxas (#5465) GTR Shock Caps and Spring Retainers
Traxxas (#5469) Rod Ends GTR Shocks Revo
Traxxas (#5472) Assembled Wheelie Bar
Traxxas (#5525) Rod ends hollow balls for Jato and Slash
Traxxas (#5531) Front Suspension Arms
Traxxas (#5535) Front Bumper
Traxxas (#5539) Turnbuckles & Camber Links
Traxxas (#5539X) Aluminum Turnbuckle set for the Traxxas Jato
Traxxas (#5556) Slipper Pressure Plate & Hub
Traxxas (#5614) Differential Kit
Traxxas (#5616) Body Mount Posts (F & R)
Traxxas (#5624) Receiver Box
Traxxas (#5636) Bumper & Bumper Mount (R)
Traxxas (#5640) Gear (14T-32P)
Traxxas (#5644) Gear (18T-32P)
Traxxas (#5650) Center Half Shafts Splined
Traxxas (#5650R) Driveshaft
Traxxas (#5653) Differential CV Output Drive
Traxxas (#5654) Stub Axle & CV Style
Traxxas (#5655) Half Shaft Set (Short)
Traxxas (#5656) Half Shaft Set (Long)
Traxxas (#5690X) Motor Plate (use with 5677X)
Traxxas (#5822) Chassis For Slash Truck
Traxxas (#5827X) Battery Hold Down for Slash Truck
Traxxas (#5862) Big Bore Shocks
Traxxas (#5872A) Rear Wheels (RD) for Slash Truck
Traxxas (#6811) Clear Body for Traxxas Slash 4×4 and Slayer
Traxxas (#6814) Center Differential Kit for Slash 4×4
Traxxas (#6815) Body Mount
Traxxas (#6823) Bulkhead Tie Bars (F & R)
Traxxas (#6829) Rear Bulkhead
Traxxas (#6830) Front Bulkhead
Traxxas (#6834) Suspension Pins Set for Traxxas Slash 4X4
Traxxas (#6835) Front Bumper & Bumper Mount
Traxxas (#6836) Rear Bumper & Bumper Mount for Slash 4×4
Traxxas (#6837X) Aluminum Left and Right Steering Blocks for the Slash 4×4
Traxxas (#6842) Spur Gear 50T 0.8 Metric Pitch for Traxxas Slash 4×4
Traxxas (#6842R) Spur Gear 50T 0.8 Metric Pitch for Traxxas Slash 4×4
Traxxas (#6843) Spur Gear 52T 0.8 Metric Pitch for Traxxas Slash 4×4
Traxxas (#6845) Steering Bellcranks & Servo Saver for Slash 4X4
Traxxas (#6853) Heavy Duty Rear Stub Axles for the Traxxas Slash 4×4
Traxxas (#6854) Heavy Duty Front Stub Axles for the Traxxas Slash 4×4
Traxxas (#6855) Aluminum Center Driveshaft
Traxxas (#6860X) Aluminum Motor Mount for Slash 4×4
Traxxas (#6863) Springs Front +10% Rate Pink for Slash 4×4
Traxxas (#6864) Springs Front Blue for Slash 4×4
Traxxas (#6867) Springs Rear +10% Rate Pink for Slash 4×4
Traxxas (#6868) Springs Rear +20% Rate Blue for Slash 4×4
Traxxas (#6877A) Clear Gear Cover for Traxxas Slash 4×4
Traxxas (#6884) Center Differential Housing for Slash 4×4
Traxxas (#6888X) Front Hardened Steel Drive Hub for Slash 4×4
Traxxas (#6890X) Plate Motor Aluminum for Slash 4×4
Traxxas (#6898) Sway Bar Kit for Slash 4×4
Traxxas (#7015) F & R Body Mount
Traxxas (#7022) 1:16 Chassis
Traxxas (#7023) Front and Rear Bulkhead Tie Bars for Traxxas 1/16 E-Revo and Slash VXL 4WD Vehicles
Traxxas (#7033) Pivot Balls and Pivot Ball Caps for Traxxas 1/16 E-Revo and Slash VXL Vehicles
Traxxas (#7034) Left and Right Axle Carriers for Traxxas 1/16 E-Revo and Slash VXL Vehicles
Traxxas (#7043) Steering Arm for Traxxas 1/16 E-Revo and Slash Vehicles
Traxxas (#7045) 45T VXL Spur Gear
Traxxas (#7046) 50T VXL Spur Gear
Traxxas (#7051) Driveshaft Assembly
Traxxas (#7071) SCT Dual Profile Off-Road Tires for Traxxas 1/16 Slash VXL 4WD RTR
Traxxas (#7122) Wing for Traxxas 1/16 E-Revo VXL 4WD RTR
Traxxas (#7132) Rear Suspension Arm Set for Traxxas 1/16 E-Revo VXL 4WD RTR
Traxxas (#7132R) Suspension Rear Arm Set, Extended Wheelbase For Traxxas 1/16 E-Revo
Traxxas (#7142) Double Tan GTR Shock Springs for Traxxas 1/16 Slash VXL 4WD RTR
Traxxas (#7143) GTR (1.15 rate) Shock Springs for the Traxxas 1/16 Slash VXL 4WD RTR
Traxxas (#7146) GTR (1.92 rate) Shock Springs for the Traxxas 1/16 E-Revo VXL 4WD RTR
Traxxas (#7147) GTR (2.06 rate) Tan Shock Springs for the Traxxas 1/16 Slash VXL 4WD RTR
Traxxas (#7148) GTR (2.22 rate) Shock Springs for the Traxxas 1/16 E-Revo VXL 4WD RTR
Traxxas (#7151) Driveshaft Assembly for Traxxas 1/16 E-Revo VXL
Traxxas (#7154) Wheel Hubs and Axle Pins for Traxxas 1/16 E-Revo and Slash VXL Vehicles
Traxxas (#7170) Talon Tires with Foam Inserts for 1:16 E-Revo
Traxxas (#7174A) Assembled Tires & Wheels for 1:16 E-Revo
Traxxas (#7184) Wheelie Bar, Assembled For 1/16 E-Revo
Traxxas (#7215) Front/Rear Body Mounts for 1/16 Summit
Traxxas (#7270) Tires Canyon At 2.2 with foam inserts
rcmart is offline
