Go Back  R/C Tech Forums > General Forums > RC Flight
shaft diameter question >
Old 01-14-2017, 09:16 AM
Default shaft diameter question
First of all, I'm new to RC flight. Why are there so many different shaft diameters? I have a micro outrunner with a 2mm shaft diameter that I'm trying to find a prop saver adapter for. I see there is this that may fit:
https://hobbyking.com/en_us/prop-sav...10pcs-bag.html
but then they also make a slightly larger one?
Will the larger one also fit the smaller one since it's the screw that is holding onto the shaft?
I see the same thing repeating for 3mms. There's a 3mm one and then a 3.17mm one?? wth? why so many variations?
lexyp is offline
