DSX9 problems
DSX9 problems
I have a DSX9 with a Flip32 using cleanflight, mostly working ok with config and esc settings. Problem I have is in the receiver page in cleanflight, when I move the throttle stick, Aux2 moves at the same time. I have tried heaps of settings in the Dsx9, tried 3 different receivers with no change. I Then tried the KK2 board, same thing! In the monitor page throttle and Aux2 are connected. So I'm thinking it's the Dsx9, but in that monitor page everything seems ok, the throttle and Aux2 work separately. I'm pretty sure I did a full reset in the service menu and still the same, My head is sore! Tia Dan
Have you got the model type set as helicopter? Helicopter settings will mix another channel with the throttle to control the pitch of the blades.
hey yeh it is, I thought that was the go? So try it in Acro mode? Cheers I'll give it a run tomorrow
No worries, acro should work better.
Or..
It's in the channel assignments and it can route from one channel to another and duplicate the sticks on an aux.
Hello
I like ask you if have problem with upgrade software of your Spectrum Tx. My friend have some problem with 9 and 18 tx...
