Go Back  R/C Tech Forums > General Forums > RC Flight
Arducopter Help >
Arducopter Help
Arducopter Help
Old 09-12-2015, 11:39 AM
intimdator10's Avatar
Default Arducopter Help
I have Quanum Nova quad that I recently upgraded the electronics in. I installed an APM2.6, 6M GPS, 3DR 915MHZ Radio Telemetry, and a Power Module. I went through the steps in Mission Planner to set up everything and it all seems to be right. When I try to arm the motors, nothing happens. I have went back through and checked everything and now I am stumped. Any suggestions to get the motors turning? I also redid the ESC calibration. Once I get it going, I have OSD to install. Thanks!
intimdator10 is offline
Old 09-13-2015, 08:39 PM
smith9turbo's Avatar
=== ArduCopter have prearm safety check ===
Copter includes a suite of Pre-arm Safety Checks which will prevent the vehicle from arming if any of a fairly large number of issues are discovered before take-off including missed calibration, configuration or bad sensor data. These checks help prevent crashes and fly-aways but they can also be disabled if necessary.
read more ... => http://copter.ardupilot.com/wiki/prearm_safety_check/
You can see what's wrong at Mission planner screen. (when you try to arm)
after all wrong was solved, then you can ARMED
smith9turbo is offline
Old 09-14-2015, 06:13 PM
Thanks! I will go through and see what is failing.
Old 09-19-2015, 10:55 AM
