Go Back  R/C Tech Forums > General Forums > RC Flight
Wiring Problems >
Wiring Problems
Wiring Problems
Old 01-23-2014, 09:18 PM
NoGoodNamesLeft's Avatar
Angry Wiring Problems
Hi
I'm new to model aircraft and I decided to build my own (probably a bad idea)
I purchased a Hobbyking GT2 2CH controller, 3CH GT2 receiver, Turnigy Park250 2200kv brushless, Turnigy 2 cell 800mah LiPo and a Turnigy 10 amp ESC.
I hooked the motor, battery, receiver and ESC together.
When I tried the throttle nothing happened.
My ESC has BEC so the receiver did have power.
If I hook a servo up to ch2 it's responsive
But I can't get my motor to spin
NoGoodNamesLeft is offline
Old 01-24-2014, 02:15 PM
dcs155's Avatar
Try reversing throttle channel on transmitter. If that doesnt work make sure throttle trim is all the way down. Those could keep the esc from arming the throttle/ motor.
dcs155 is offline
Old 01-24-2014, 02:17 PM
dcs155's Avatar
Not a bad idea on your part at all for assembling your own model btw, no better way to learn, good job!!
dcs155 is offline
Old 01-24-2014, 02:25 PM
dcs155's Avatar
Also try changing 2 of the 3 wires going to the motor from esc. Just unplug any 2 and plug them in the opposite plugs.
dcs155 is offline
Old 01-24-2014, 04:05 PM
Tried it out and it worked
Cheers mate
Old 01-24-2014, 08:07 PM
dcs155's Avatar
Glad it worked for ya! What type of plane you gonna build?
dcs155 is offline
Old 01-25-2014, 12:17 AM
My intentions are to build a high speed plane
I have designed a swept back wing with a special wing tip.
The motor is mounted backwards towards the tail planes
Two propellers are mounted in the leading edge of the plane driven by a single motor through a gear system.
The reason why the props are mounted in the tail planes is because the air at the front of the main wings is turbulent thus by mounting behind the wing the air is cleaner.
Old 01-25-2014, 02:55 AM
dcs155's Avatar
Thumbs up
Sounds like an awesome design and project! Keep me posted on your progress. Always cool to see new inovative " out side the box" flying stuff
dcs155 is offline
