Go Back  R/C Tech Forums > General Forums > RC Flight
Problem calibrating my quadcopter. Please help!! :( >
Old 05-19-2013, 10:10 AM
Default Problem calibrating my quadcopter. Please help!! :(
Hi all, i just got my quadcopter from h t t p : // shop.rotor.com.sg/show-detail.asp?prodid={77AA67C2-D879-40F8-B8B9-F5E4110DF887}&pn=1#.UZj2WkrTT7E
I have problem calibrating the yaw,pitch and roll therefore, whenever i try to take off, the whole thing will just flip.
Here is the manual:
h t t p s : / / docs.google.com/file/d/0B_JCA3Yx_nFtQkxNdEpoR2R5V3M/edit?pli=1
Can someone help me to translate into a more understandable english?
Many thanks.
ex7rema is offline
Old 05-22-2013, 06:00 PM
trickedout's Avatar
Trader Rating: 31 (100%+)
Check over at r c groups. com much better multirotor support.
trickedout is offline
Old 06-02-2013, 11:37 PM
Suspended
Calibration is an ESC thing, and the procedure might be different from other ESCs. The flight controller only passes on the throttle signal (with some modifications) from the receiver to all ESCs at the same time.
I suggest you practice by connection one of them directly to the receiver (throttle channel), and follow the instructions for your ESC. When you find out how to do it, do them all together via the KK2.
Regards.
Andy.
Andy159 is offline
Old 02-11-2018, 12:12 PM
I had the very same issue.. there are 5 things to check to ensure everything is working fine:
1- Calibrate the Acelerometer
2- Verify the Motor Rotation
3- Check the Propellers
4- Configure PID parameters
5- Double-Check Connections
Actually created a video on how to solve the issue but the page is not allowing me to post the link :-(
erpoyo is offline
