Go Back  R/C Tech Forums > General Forums > RC Flight
1830mm Super Cub Motor/ESC recomendation. >
Old 07-02-2012, 06:37 PM
HR1140's Avatar
Default 1830mm Super Cub Motor/ESC recomendation.
I just bought this as my second plane to my champ. I plan on getting a spektrum DX6i, have all the servos that were extras from my cars. If I were to use a 5000+mAh 4s pack, what motor, esc, and prop would you use?
I would like a wood prop, and probably around a 60A esc, other than that I am clueless.
Link to plane:
http://www.cmpairplane.com/EP-Airpla...low%20Cub.html
HR1140 is offline
Old 08-10-2012, 03:13 PM
Trader Rating: 78 (100%+)
Default esc/batt
I don't run anything bigger then a 2200/3s, weight. I have a 3028 850kv on my cub with a 9x6 and a 30amp esc. You'll probably find your car servo's to big and heavy. My big plane takes 37gr servo's and my cub has 9gr servo's in it. I'm also running a 3s/1300 in it. 10 min's is as far as I've gone yet. I didn't firewall it for very long and had plenty of twist to go inverted.
btrukr is offline
