F15E, 1800mm, Tetris, Bukvorez.
Hi everyone!
F15E-Tetris, Bukvorez, 1800mm project. Responses modelers yielded results. Draw, cut, glued. Started F15E, length 1800mm, 86-98mm impellers. Estimated weight to 500gramm. In this project, chose a slightly different approach to internal cutouts. It is easier to form a canal impellers for different tasks. not a quick project, I know. but in the final stage. prepared and cut two fifths of the model. other plan in the coming days. http://bukvorez.ru/images/stories/mo...rk_cut/001.jpg http://bukvorez.ru/images/stories/mo...rk_cut/002.jpg http://bukvorez.ru/images/stories/mo...rk_cut/003.jpg http://bukvorez.ru/images/stories/mo...rk_cut/004.jpg http://bukvorez.ru/images/stories/mo...rk_cut/005.jpg |
Ready to F-15E STRIKE EAGLE.
With this model used a slightly modified technique of preparation of drawings, which allowed to approach the performance of authenticity. http://bukvorez.ru/images/stories/models/f15e/007.jpg http://bukvorez.ru/images/stories/models/f15e/008.jpg http://bukvorez.ru/images/stories/models/f15e/010.jpg http://bukvorez.ru/images/stories/models/f15e/018.jpg http://bukvorez.ru/images/stories/models/f15e/021.jpg |
experimental model.
weight of 650 grams foam with wings. http://bukvorez.ru/images/stories/models/f15e/048.jpg http://bukvorez.ru/images/stories/models/f15e/033.jpg |
Nice Build. I must say that this is one of the best models that I have seen. The pieces are formed and fit with an amazing amount of precision and this turned out to be a beautiful model. That really shows the amount of time you will spend making the model I would recommend this to anybody. That is closer to the real thing than any of the other models in the market.
