New or used helicopter
is it worth to spend half of the price to get a used helicopter instead of a new one? I am just a beginner. you comment would be great!
Dan
I think it's very rare to get a used helicopter that works normally. I bought a used align trex 450 se v2. I found that the main shaft and tail rotor shaft are bent and also the main gear does not spin smooth. I though that is not worth to buy a used helicopter.
That's all simple stuff, but you should just ask the seller for a partial refund for the parts if he stated the helicopter to be in running condition. A used helicopter is alright. Just rip the helicopter apart, get a manual, and then build it from there so you KNOW the helicopter's built right.
when you want to buy a used helicopter, it's better to buy a locally and ask the person to fly it and see if make any kind of strange noise or vibration when it starts up. if you don't have any experience at all, don't buy a used helicopter.
New or used, you're bound to spend extra money on parts eventually, helicopters are a huge money hole. Expect the worst, and assume you're going to need to fix stuff when you buy used, then pay accordingly.
yeah..that's right. if you want to get into this hobby, you really need to spend time and money on it.
Hey
Have you looked at the Mcpx, just had a price drop and really tough
If you're new to this hobby i'd start with a 4 channel heli that is easy and cheap to repair.
Better to buy a new one than a used one, most of those helis have had some crashes and if you're new to this you don't want to start repairing things, you want to start flying
i'm a big fan of the Walkera V200D02 or 01 as a starter heli. Not expensive, easy to fly and easy to repair. Lots of parts availible and the heli can easily last you some time before you out grow it.
just google it.
if you want to start out with a collective pitch try looking at a 250 sized to keep things affordable, or a 450 one if you are willing to spend something and have more stability and maybe a faster learning curve.
Good Luck
just google it.
Good Luck
Since you are new to heli a used one would be ok you just have to make sure everything is where it should be. I would suggest you buy new. If your new to flying I would not suggest you get a heli bigger than an mcpx. If I was you I would go with a beginner heli maybe something FP. Let just say that if you decide to go with bigger make sure no one is around you. I say this because I have not see anyone new not crash in the first few flights. The bigger the heli the more$$$$$ you spend in repair.
Word of advice learn throttle hold cause it will be your friend when learning to fly heli.
Buy new
I just bought a used 120sr and it worked perfect. Half the price of new and with extra batteries and parts. I have a gotten into a habit of buying used as it saves a ton due to the fact of people not sticking with things. Also you can buy an item that someone bought and never used. Many people have 450 helis that they got a full setup for and were scared of crashing so never flew it. You could save a ton on that type of thing.
I.M.O. i would buy new. that way you have a chance to build it and see how everything goes together. along with a manual and possibly a parts list with the new heli
