LF airplane to match my equitment
Hello, i have had several airplanes in the past but have wrecked or sold most of them. I have a hacker a20-22l with hacker 18-3p esc. I do have 3, 2 cell 4000mah battery but i am ok with buying another battery. Just im not sure what size airplane i can power. The info on the motor is:
Kv (rpm/V) 924
Max Power (W) 190W
Max Amp (15sec) 17A
Max Efficiency 85%
Io (No load A) 0.75A
Rm (Resistance) 0.089Ohm
Shaft Diameter 3mm
Gearbox N/A
Motor Diameter 28mm
Motor Length 32mm
Motor Weight 57g
Built in Fan Sold Separately
Max Rpm 20,000
Poles 14
Case Outrunner
ESC Timing 20-25 deg
ESC Switching Freq. 8-16KHz
I have a hanger 9 twist with a .46 but that is a little too much. Id like something similar to a twist that is easy to fly but has the potential to do a few aerobatics.
I appreciate any help i can get.
Kv (rpm/V) 924
Max Power (W) 190W
Max Amp (15sec) 17A
Max Efficiency 85%
Shaft Diameter 3mm
Gearbox N/A
Motor Diameter 28mm
Motor Length 32mm
Motor Weight 57g
Max Rpm 20,000
Poles 14
Case Outrunner
Kv (rpm/V) 924
Max Power (W) 190W
Max Amp (15sec) 17A
Max Efficiency 85%
Shaft Diameter 3mm
Gearbox N/A
Motor Diameter 28mm
Motor Length 32mm
Motor Weight 57g
Max Rpm 20,000
Poles 14
Case Outrunner
Kv (rpm/V) 924
Max Power (W) 190W
Max Amp (15sec) 17A
Max Efficiency 85%
Shaft Diameter 3mm
Gearbox N/A
Motor Diameter 28mm
Motor Length 32mm
Motor Weight 57g
Max Rpm 20,000
Poles 14
Case Outrunner
its equivalent to a 400 size motor,
my personal favorite for that motor would be an mscomposit plane, something like the unique, most of the planes on this page will fly with that motor/esc combo.
http://www.commonsenserc.com/index.p...3dcllja3qo5k63
eflite park370-400 series.
http://www.e-fliterc.com/Products/De...ProdID=EFL2175
a cheap stick style plane
http://www.valuehobby.com/product_de...54&item_id=376
Wow, thank you VERY much for all the infromation
