blade cx2 Q
The stock charger that comes with the Blade CX2 can only charge 2S packs. You would need to buy another charger if you want to charge a 3S pack. Just to let you know you shouldn't be using a 3S pack with the Blade CX2. The motors will be fried in no time. If I were to buy some upgrades I would go with the heat sink, alloy inner shaft and bearing block. The rest of the upgrades are kind of useless. The carbon tail boom works all right, as it lowers the over all weight and it flies better and longer.
Take Care,
Cheers, Patrick
Take Care,
Cheers, Patrick
r they any good
Take Care,
Cheers, Patrick
Take Care,
Cheers, Patrick
another Q
I am looking to buy some new batteries for my CX2 (I left one plugged in and ruined it ) I looked on line I am not sure which is better 15c 850mah or 10c 900mah??????
Any suggestions?
Not really sure if 15c if required for the CX2. I have stock motors right now but I do plan on upgrading to the BB ones.
Any suggestions?
Check out the BladeUpgrade pack from FlightPower. Its 800mah, 18c & roughly $4 bucks cheaper than a stock replacement. It comes with the OEM plugs on it just like the stock pack so the stock charger is fine. If you dont use the stock charger then they have adaptors that will be aval. in the next week or so that will allow you to hook a balancer up to the plug the stock charger used & charge theough the main leads. This adaptor should work on the Eflite pack as well so it can be charged & balanced with a better charger.
Yea at first it looks like it will throw the CG off but it dosent. Works well though.
Thanks guys, but what i am looking for is should i be more concerned with "mah" or the "c"
I have a 3 cell in my CX. Better hold on, wow....
