-   RC Flight (https://www.rctech.net/forum/rc-flight-109/)
-   -   Servos not responding to RC Controller (https://www.rctech.net/forum/rc-flight/1103748-servos-not-responding-rc-controller.html)
cjannetta 09-06-2022 09:24 AM
Hello,
I am a beginner at building a RC drone and have been having an issue with getting the servos to respond when using an AT10 Radiolink controller. I am using an iFlight F7-Succex-D flight controller and a SucceX 50A 2-6S BLHeli_32 Dshot600 4-in-1 ESC. I am trying to use an SBUS connection with my Radiolink R12DS receiver. When the flight controller is connected to Betaflight via USB, the receiver displays that the flight controller is receiving the outputs from the controller, but the servos and motors do not respond. When using Betaflight to test the motors it works perfectly fine. The UART port I am using is correct and has already bet set to SerialRx. The receiver has already been bound to the RC controller, and has already been set to SBUS. The yellow wire in the picture attached is to R1, the red wire is to +5V, and the black wire is ground.
Thanks.
cjannetta 09-06-2022 09:26 AM
FC Pictures
1 Attachment(s)
Here is the pictures of the FC.
