Go Back  R/C Tech Forums > General Forums > RC Flight
Cirrutitan tethered device for greater stability and efficiency >
Old 08-19-2019, 04:34 AM
Default Cirrutitan tethered device for greater stability and efficiency
Cirrutitan is a new generation of MMC-developed UAV tether system, featuring small volume, low noise, long service life, quick response, and high efficiency. From the video, it can be seen that Cirrutitan is equipped with MMC standard connector that can match to any payloads also equipped with the connector, enabling users to match it with different payloads according to different needs. In addition to receiving power, The sky-end of Cirrutitan also has over current protection, over-voltage protection, over-temperature protection, and short circuit protection functions.
The video of the operation:
https://youtu.be/k6n4HfbgKVw
Jeff Bewkes is offline
Old 08-19-2019, 09:48 PM
I have a question about this charging device. Is the power on the ground connected directly to the drone?
Flying racer is offline
Old 08-19-2019, 11:59 PM
  • I think it's a big engine to charge the drone
Richard Jackman is offline
Old 08-20-2019, 01:12 AM
In fact, each type of tethered device has a sky component and a ground component. Sky parts are "hubs" for drones and cables.
Old 08-20-2019, 01:18 AM
This could easily create a high voltage and cause the drone to fail.
