Go Back  R/C Tech Forums > General Forums > RC Flight
Single Fan Thrust Vectoring VTOL Project - MonoPhan >
Old 02-09-2020, 05:30 PM
  #16
VAALLEON's Avatar
Quite a windy day, great opportunity to test the skills of the little watcher and get some closeup footage of the flight, thrust vectoring and active wing compensation. Amazing little thing started the build journey very rough, not even hovering properly and crashed tens of times. But now it turned out to be the most skilled watcher I have built, which I have learned configuration tricks from which I will use on the bigger units. If you like aeronautics and flight in general you will definitely enjoy this video, especially the close-ups. I changed the attack angle setting multiple times during the flight so some passes have the higher and some have the lower attack angle.
VAALLEON is offline
Old 02-17-2020, 01:46 PM
  #17
VAALLEON's Avatar
Indoors hover maiden of the bigger Ardupilot unit. Looks pretty well balanced and controllable. Ourtoors is a completely different game and may immediately crash, but this is a good start.
VAALLEON is offline
Old 02-28-2020, 04:03 PM
  #18
VAALLEON's Avatar
The new sub250g unit. There is a little bit of flutter but other than that flies like a charm & looks like it will exceed 10 minutes flight time which is pretty impressive for a tiny VTOL like this
VAALLEON is offline
Old 03-01-2020, 06:55 PM
  #19
VAALLEON's Avatar
Strong winds and a good test. The new unit handles very well but needs a little further tuning. Good test with some awesome close-ups.This tiny one can get +10 minute flight time
VAALLEON is offline
Old 03-07-2020, 10:24 AM
  #20
VAALLEON's Avatar
The wind is so strong it knocks down the unit before take-off, so I have to hold it down. Good test, a couple of glitches that will need to be adjusted.
VAALLEON is offline
Old 03-21-2020, 03:00 PM
  #21
VAALLEON's Avatar
VAALLEON is offline
Old 04-04-2020, 07:01 PM
  #22
VAALLEON's Avatar
After many motor failures, testing a modified EDF motor in hover. Position and altitude hold. This is an Ardupilot Arduino hybrid. Windy day testing the skills of the unit...
[email protected]
VAALLEON is offline
