Go Back  R/C Tech Forums > General Forums > RC Flight
Searching for reversible shaft 50cc equivalent outrunner and above motors >
Old 07-17-2018, 12:36 PM
potatocat's Avatar
Default Searching for reversible shaft 50cc equivalent outrunner and above motors
Hi all,
I am looking to use a 50cc and above brushless outrunner for a non-airplane project.
The trick is, I am looking for a motor which has a reversible shaft. Basically instead of using the prop-side, I need the shaft to come out the other end of the endbell.
It seems that most of these big motors don't have much documentation and of them only a handful have replaceable main shafts. Even if the process of flipping the shaft requires me to modify the existing one, or machine a new one- that's okay. I can lathe something up. I just need to be able to do this without having to hammer out an existing shaft or do anything which requires rebalancing the armature.
Thanks for reading!
potatocat is offline
