Go Back  R/C Tech Forums > General Forums > RC Boating
R2 Hobbies 36" Cat build. >
Old 01-19-2015, 02:18 PM
Default R2 Hobbies 36" Cat build.
I just received the hull, and I am impressed with the quality. The plan is to do a single Tekin T8 motor, which I had laying around, and a 180AMP ESC from Offshore Electrics. It will run on 5 or 6 cells. I am waiting for all the drive componenets coming from Hong Kong. Meanwhile, I began decorating the hull, and figuring out how to make a water cooling jacket for a finned motor, designed for air cooling!
Enjoy the photos.
cygnusx1 is offline
Old 01-19-2015, 02:36 PM
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
You might want try less cells with that motor or get a low kv motor to run 5-6 cell lipo.
roadrashracing is offline
Old 01-19-2015, 02:44 PM
You think? It's a 2250kv motor. Will 5S-6S over spin it? I used to run it on 4S but with 5S everything seemed to run cooler...if that's possible.
EDIT: Yup. This page spells it out nicely.
http://www.radiocontrolinfo.com/rc-b...ss-boat-motor/
cygnusx1 is offline
Old 01-19-2015, 04:56 PM
Moderator
Go with a motor with a cooling jacket and motor like this and you will be a lot more happy, just not sure how good your homemade stuff would work.
http://www.offshoreelectrics.com/pro...artan-Combo-v3
Old 01-21-2015, 02:41 PM
Excited to see the completed boat
leothegreat is offline
Old 01-28-2015, 09:12 PM
Some updates.
I did some more graphics on the hull in silver carbon vinyl, and white pin striping.
I received the hardware and installed it. I made a backing plate out of Delrin to help support the rudder/strut. I installed the drive tube and shaft. I completed the cooling jacket for the Tekin, and it holds pressure. It also has a lot more volume than the typical cooling jacket which is good for burst cooling. But, I did decide to pickup a different motor too. I will complete the boat with the Tekin motor, but I will switch to the leopard motor when I am more comfortable with the boat.
The Leopard is a 4200 watt 4-pole unit 1480kv. That's about 5.6 Horsepower on 6S at 115 amps. I got a good deal on ebay for it. I think it's too much power but we shall see.
cygnusx1 is offline
Old 02-11-2015, 04:59 PM
The motor was too high for the cowl, so I cut and lowered the "firewall", and removed some ply from directly under the motor, for clearance.
Rear battery location gives a good CG location.
Used a Traxxas truck box to keep the Rx dry, and the wiring tidy.
Ready for Spring.
cygnusx1 is offline
Old 02-12-2015, 05:57 AM
Moderator
Turned out nice.
Old 02-12-2015, 09:55 AM
Trader Rating: 17 (95%+)
Excellent build, should be fast as hell.
Pintobean11 is offline
Old 05-01-2015, 06:51 PM
Well, you be the judge. It still needs some strut angle and depth adjusting, and I think the rudder is a tad too small, but when it settles in a straight line...
+ YouTube Video
https://www.youtube.com/watch?v=_HPXtfW6Kdg
Build tip:
Add glass reinforcement under the deck, around the four corners of the hatch opening. It begins to crack there rather quickly.
cygnusx1 is offline
Old 05-04-2015, 10:53 AM
R/C Tech Elite Member
TIME MACHINE's Avatar
Trader Rating: 70 (100%+)
That's one heckuva' boat. Like a fine piece of art!
TIME MACHINE is offline
