Go Back  R/C Tech Forums > General Forums > RC Boating
Any info will be nice >
Old 12-26-2014, 01:45 PM
Default Any info will be nice
so my stepdad pulled this out of his shed and brought it to my moms house any info on it will be nice we havent run it yet he says he built it as like a kit
rc car freak is offline
Old 12-26-2014, 06:09 PM
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
What did you want to do with it? Maybe an old dumas model? Any markings on the motor?
roadrashracing is offline
Old 12-26-2014, 06:19 PM
just curious about how reliable it will be in calm water he hasnt ran it in years. it will be run in calm water. a city resevoir thing idk what it is but its like greenish water on top of a city hill with a pipe going into it that water goes through sometimes.
Old 12-26-2014, 06:34 PM
Moderator
Might not be a good place to run it, might be able to run it on short grass, not something I would put a lot of time and money into. Engine might need airplane fuel.
Old 12-26-2014, 07:24 PM
Ron Olson's Avatar
That's a Dumas Products airboat. http://www.dumasproducts.com/product...roducts_id=204
Ron Olson is offline
Old 12-26-2014, 07:35 PM
lol your signature is true for rc bashing at a park too. it has an os max s engine on it.it has 2 futaba s23 servos those things are old and taller than 1/10 servos. my stepdad never drove it he only started it once and put it in the shed. im just curious is it any good ive never driven an rc boat
Old 12-27-2014, 09:14 AM
Ron Olson's Avatar
It can be a fun boat if you get it running. You can run it on wet grass and snow (if you live where it does that) or scoot it across the water. You can do that drifting thing with it on water.
Old 12-27-2014, 11:30 AM
well there is compression in the engine and we are letting the carb sit with some wd 40 to clean it then it should
Old 01-30-2015, 08:26 PM
31Bowtie's Avatar
Wink Dumas Big Swamp buggy
It can be a lot of fun, they recommended like a .35 motor but they work a lot better with .45-60 size motor. boat is kind of heavy. It will fly with a .60 and go across the grass. You might want to try nitro cleaner instead of wd40. It dissolves the fuel and gummed up oil better. But once you take it out of the nitro cleaner you need to oil it! you can pick an OS 40 or 45 off e-bay pretty reasonable if it doesn't work.
Boat does not look like it is in too bad of shape just needs some TLC and cleaning. go boating!
31Bowtie is offline
