Tips on making a boat?
I want to build a boat from scratch under $100. Any tips? thanks:)
This is about all you are going to get, its close with all the electronics they have.
http://zippkits.com/~zippkits/index....roducts_id=498 $100 for a whole boat you are kind of dreamen sorry. |
Originally Posted by roadrashracing
(Post 13456094)
What kind of boat and whats a total budget, build a hull for $100 might be likely.
(Post 13456147)
electric I take it?
(Post 13456153)
electric I take it?
so are you against a wood kit?
(Post 13456157)
I would build a mono, I would at least work off some plans, and do lots of reading. You should set a budget more of like $300-$400 by the time you get hardware and electronics etc. They do make good kits where the wood is all cut and you still have to put it together.
If you where to get something like this I think you would be very happy.
http://www.offshoreelectrics.com/pro...rod=ch-Blaster |
TMistak..
1st how large do you want it? Id go with a balsa coated with laminate.carbon fiber or fiberglass. lay the keel then ribs then stiffeners.. transom.. what power plant are you putting in it ? Im a Certified Marine Mechanic and have built many Boats ships yachts from scratch.. IM me we can talk.. |
Originally Posted by ElectricMann
(Post 13456355)
TMistak..
Frankly, a C-note will barely cover the electronics much less the rest of the boat. Buy a cheap backyard flyer and mount it on some foam blocks to make an airboat out of it.
Sctatch built
we used mahagoney door skins 5/32: 3 ply plywood very strong get some hardwood stringers cut out a plan of your own design ( use card board first)
one door skin can make a 3-4FT boat easy. you can wet it and then you can shape it. clamp in place let dry. I used spray foam to fill the front bow and hold the fuel tank in place. we used to make weed eater mono's been a few years but we could get the door skins for $27 probably more now but you should be able to build a hull for less that $100. Built out riggers for less. same methods. Go old school. :nod: |
