Go Back  R/C Tech Forums > General Forums > RC Boating
DUMAS Scarab build >
DUMAS Scarab build
DUMAS Scarab build
Old 12-05-2013, 09:01 PM
DirtTrixx's Avatar
Questions?? DUMAS Scarab build
any input would help guys as you can see from my photos i cannot get these anti vibration mounts to work the holes drilled in the stringers seem to be to far apart unless im just not seeing it... Possible but if you guys can send me a link to solid motor mount for g230pum between 5" stringers gotta get this figured out my stinger will be here soon thank you for any input.
Attached Thumbnails DUMAS Scarab build-unnamed-1.jpg   DUMAS Scarab build-unnamed-2.jpg   DUMAS Scarab build-unnamed-3.jpg   DUMAS Scarab build-unnamed-4.jpg   DUMAS Scarab build-unnamed.jpg
DirtTrixx is offline
Old 12-06-2013, 01:08 PM
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Are you installing new strings in the boat, I take it?
I would go with these mounts:
http://zippkits.com/~zippkits/index....roducts_id=224
Just drill new holes.
roadrashracing is offline
Old 12-06-2013, 01:49 PM
DirtTrixx's Avatar
No new strings the ones in the hull are good is the spacing standard
Old 12-06-2013, 03:55 PM
Moderator
you might need different mounts then with those rails.
Old 12-06-2013, 07:06 PM
Ron Olson's Avatar
Yup, those are really bad motor mounts as somebody cheaped out! They used a standard Zenoah rear plate which most people toss in favor of a better mount. It's probably what they might have used back in the day when that Zenoah 230/231 came out.
Ditch the velocity stack as most of them will make you lose speed, it's more cosmetic than anything.
Ron Olson is offline
Old 12-06-2013, 09:11 PM
DirtTrixx's Avatar
Thanks Ron yea I just picked this winter project up all for dirt cheap thank yall for your input greatly. Appreciated
Old 12-07-2013, 01:46 PM
Moderator
you could use the back mounts, just flip them 180. I will take a picture of mine once the camera is charged.
Old 12-07-2013, 01:49 PM
Moderator
otherwise you could go with these and get some new rubber blocks. Just not very big stringers. Fyi, if it is an older zenoah 230, new heads will not fit.
Old 12-07-2013, 11:13 PM
DirtTrixx's Avatar
Did you happen to snap a pic of those mounts
Old 12-08-2013, 02:25 AM
Moderator
sorry forgot, I will in a few hours.
Old 12-08-2013, 11:58 AM
Ron Olson's Avatar
That mount is a little messed up after giving it another look. That bracket on the front should be mounted upside-down on the top of the block. Use a washer if you need to to fill in the gap, preferably on the port side to offset the engine to the starboard side.
Old 12-08-2013, 12:47 PM
DirtTrixx's Avatar
Ahah thanks Ron I do have a second question what should I run on the end of this carb rather than the velocity stack?
Old 12-08-2013, 01:01 PM
Moderator
nothing, just bolt it on, hear is a picture I found of my old motor with the mount you might need.
Old 12-08-2013, 04:08 PM
DirtTrixx's Avatar
Is that the zip kits mounting plate kit? also how far apart are those holes drilled in your stringers? thanks for all your help Greatly Appreciated!
Old 12-08-2013, 04:09 PM
Moderator
I know the back mount is bonzi, I'm not sure about the front.
