Zenoah help
Old 12-05-2013, 07:52 PM
DirtTrixx's Avatar
Exclamation Zenoah help
guys i cant get this output shaft collet "thing" off the shaft of my motor what is this and its purpose? please advise
Thank you
DirtTrixx is offline
Old 12-06-2013, 08:35 AM
there should be a screw down inside that you have to unscrew,then you can just twist it off.install a piston stop ,so you can with a wrench twist the collet off ,once the screw is out.or pull the jug and brace the crank to stop it from spinning so you can get it off.
baumer65 is offline
Old 12-06-2013, 10:08 AM
DirtTrixx's Avatar
Thanks man I got that sucker off you have any recommendations for a clutch
Old 12-06-2013, 01:07 PM
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
I would personally not use a clutch.
roadrashracing is offline
Old 12-06-2013, 07:00 PM
Ron Olson's Avatar
Geez RRR, don't let the Dock boys see this, they'll be having kittens!
I would have just put a wrench on the square drive then broke the bolt loose.
They had a conniption when I told them how to remove a regular collet without spending insane money on a fancy assed tool.
Like he said, forget about a clutch, just watch yourself and others around a spinning prop.
Ron Olson is offline
Old 12-08-2013, 08:11 PM
DirtTrixx's Avatar
did throw a wrench on that sucker but it just spun the crank
Old 12-08-2013, 08:35 PM
Ron Olson's Avatar
Did you remove the Allen bolt down inside of the collet? Collets will stick the that Allen bolt presses the collet against a tapered surface. I haven't had to deal with square drives before so I don't know the trick to pop off the collet if you got the bolt out.
A crude way that I can think of off-hand would be to get a long 5mm Allen or regular bolt, put the engine in a vise and clamp it down at the collet, thread the bolt in and give it a few taps with a hammer until it pops loose.
Old 12-08-2013, 09:08 PM
DirtTrixx's Avatar
ron i posted this on my other thread but i really would like your input so i want to nake sure you see it what are your thoughts
I am going to covert this hull from a strut/dual rudder drive by Marine Specialties to a stinger for surface drive and still use the rudders just remove the strut which leads me to two questions>? the stinger and prop should ride in front of the leading edge correct? or trailing behind.? secondly from the collet do i run a brass shaft tube through a T-bar along the buttom of the hull to the transom were it will meet the stinger and run my flex shaft through the brass?
