Go Back  R/C Tech Forums > General Forums > RC Boating
Proboat Thunder cat 31 >
Old 11-03-2013, 03:13 PM
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Default Proboat Thunder cat 31
I picked one up the other day, and am just wondering what the stock motor is capable of, I've got a few props to mess with.
roadrashracing is offline
Old 11-03-2013, 03:20 PM
hotrod87's Avatar
Trader Rating: 252 (100%+)
Looks fast just sitting there.
hotrod87 is offline
Old 11-03-2013, 04:00 PM
Moderator
Flames make anything look fast.
Old 11-03-2013, 04:55 PM
Ron Olson's Avatar
OK, I've had the chance to play with a couple of them but never owned one.
You're kind of limited as the engine is considered a Sport engine.
Here's what we did:
Swapped the prop out for an Octura M-445 but a Zippkits 444 would work also, gained a lot of speed there.
Port match the header as in stock form it really blocks exhaust flow.
We ran it with 65% nitro but we're sort of nuts anyway.
Placed a 10oz. fuel tank in the rear right side of the sponson to move the CG back. You can keep the stock one in place if you want to.
The carb also limits its potential as the bore is too small choking it there too.
Ron Olson is offline
Old 11-03-2013, 05:06 PM
Moderator
I don't expect a lot out of it, just something else to play with.
Old 11-03-2013, 05:22 PM
Ron Olson's Avatar
Yeah, right! We all like to squeeze a few extra MPH out of the boats.
Most of these changes are no to low-cost mods.
One more thing that's kind of important. Make the rudder so that it's break-away, a nylon nut and bolt in place of the lower one will help a lot. Crack the top bolt loose just a hair, just enough so that it can swing away. It's getting harder to find replacement rudders as a lot of people broke them. The problem was also on the Shockwave 36.
hotrod87's Avatar
True very true.
hotrod87 is offline
Old 11-03-2013, 05:48 PM
Moderator
I'm trying to find just a gas cap, I don't want to have to buy a whole new tank.
Old 11-03-2013, 05:57 PM
hotrod87's Avatar
Don't they sell just a cap ?
hotrod87 is offline
Old 11-03-2013, 06:05 PM
Moderator
Not that I could find just, the whole tank. I got new fuel lines and water lines ran, I might be running it this year yet.
Old 11-03-2013, 06:07 PM
hotrod87's Avatar
Sweet. Get vids. Please.
hotrod87 is offline
Old 11-04-2013, 05:09 AM
Ron Olson's Avatar
Gas caps? Sometimes that's easy. Check around the house to see if you've got a bottle cap that'll fit on it. The AquaCraft nitro boats used an ordinary pop bottle cap if you lost one.
If you can't find one go to Plan B and use a Sullivan tank in it.
Old 11-04-2013, 05:29 AM
Moderator
thanks for the tip, soda cap works perfect.
Old 11-04-2013, 07:18 AM
hotrod87's Avatar
Get that sucker fired up and let's see some vids. I'm gonna be relying on YouTube for my boat fix pretty soon.
hotrod87 is offline
Old 11-04-2013, 09:18 AM
Moderator
Don't have fuel or a starter.
