Go Back  R/C Tech Forums > General Forums > RC Boating
Brushless motor for boat >
Old 09-16-2013, 06:36 PM
hotrod87's Avatar
Trader Rating: 252 (100%+)
Default Brushless motor for boat
Is everyone running 4 or 6 pole ? I just got a tacon 1800kv 2pole 3660 and I'm wondering if it'll work ok in a 26 in Rio .
hotrod87 is offline
Old 09-16-2013, 07:50 PM
R/C Tech Elite Member
Slo_E4's Avatar
Trader Rating: 59 (100%+)
I'm sure it would work fine without over propping. More poles will obviously run cooler but it should be fine. You could run 5s, but I'd stick with 4s since its such a small motor. Pair it with a sk120 and it would be a sweet setup I'm sure.
Slo_E4 is offline
Old 09-16-2013, 08:14 PM
hotrod87's Avatar
Thank you for the input. Was gonna try the proboat 60a esc I have with 4s . I really need to invest in a better esc.
hotrod87 is offline
Old 09-16-2013, 08:46 PM
Cinnabun's Avatar
Trader Rating: 26 (100%+)
3660 is kinda small. Not gonna have much torque to spin a prop.. The aq motors are 6 pole why not run one of them rod? My leopards are 4 poles but also alot more can. 3674 and 4082. I like high kv low voltage personally.
Cinnabun is offline
Old 09-16-2013, 08:52 PM
hotrod87's Avatar
I know I have a aq motor on the way just trying to find a use for this 3660. I guess I could put it in my stampede and run 4s. Lol. Just trying to build the Rio on the cheap with a brushless setup.
hotrod87 is offline
Old 09-16-2013, 09:01 PM
Cinnabun's Avatar
I know you have one on the way, I know the guy you got it from lol. Seriously the aq motor and 60a esc would probably be a nice combo in the rio.
Cinnabun is offline
Old 09-19-2013, 07:42 PM
I have a Tacon 3660 2200kv running on 4s in my SuperVee 27. Quite a boost in performance. Found a X637 prop is working the best for me so far. Running a stable wet hull at 46mph (gps) with motor temps around 100f after a 5min run. Using the 60a AquaCraft ESC out of my UL1. Great motor, many runs so far.
Fast1Guy is offline
Old 09-19-2013, 09:22 PM
hotrod87's Avatar
I thin I'll try it in the Rio on 4s with the stilleto 60a esc and stock prop first. What's the worst than can happen ? I'll just take the rescue boat (villain) with me.
hotrod87 is offline
Old 09-19-2013, 10:55 PM
Slo_E4's Avatar
Hull came brushed, nicd battery, with a 1/8 shaft. Going brushless, you don't need much torque. Cool thing is, is that your (Ill assume) 50mm long jacket should smother that short motor so cooling should be good.
Slo_E4 is offline
Old 09-27-2013, 05:09 PM
31Bowtie's Avatar
Default boat motors
This might help. http://www.radiocontrolinfo.com/RCca...Calculator.php
31Bowtie is offline
Old 09-27-2013, 05:53 PM
hotrod87's Avatar
Thank you I'll check it out.
hotrod87 is offline
