Go Back  R/C Tech Forums > General Forums > RC Boating
Graupner Hydrospeed >
Graupner Hydrospeed
Graupner Hydrospeed
Old 09-15-2013, 05:18 PM
Default Graupner Hydrospeed
A blast from the past in perfect condition
Does anyone have an assembly/instruction manual kicking around?
Enjoy
Attached Thumbnails Graupner Hydrospeed-p1010597a.jpg   Graupner Hydrospeed-p1010598a.jpg   Graupner Hydrospeed-p1010602a.jpg   Graupner Hydrospeed-p1010605a.jpg
Massastan is offline
Old 09-19-2013, 02:58 PM
Don't have the manual but I used to have one. Was there a question you need answering?
Alex
niterdr is offline
Old 09-21-2013, 04:54 AM
Yes, maintenance of the drive shaft and gear reduction transmission
Thank You
Old 10-07-2013, 12:16 PM
Sorry for the delay, I never received a notice you replied. Maintenance on the gears is quite simple you just put a little light grease on them, normally you don't even need that but we found it helped keep them from wearing. The shaft needs a barrier to keep water out and lube the bushings, Pro-Boat makes a good grease that won't dissolve in water, don't use much as too much a small amount in the stuffing tube and a little at each bearing is all you need.
Alex
niterdr is offline
