BlackJack 26 SS Nitro
Hey guys I just picked up a really nice bj26 ss nitro and was wondering if there are any tips or anything I should do to it before taking it to the lake. So far it is all stock with the stock .18 motor that has great compression. I have taken off all the stickers and made it black/white/red scheme and it looks great. I have noticed that there are 3 holes on the lid that are open and wondering if I should plug them or not.
I haven't ran it yet or started it because I need to go get fuel, glow igniter, new glow plugs, and a rx/tx, fail safe.
So is there anything else I should get for it or is that a pretty good start for my first boat?
I also have a airtronics mx3-x radio and was wondering if I can use it on the boat. I read on hobby people that it says its for car, trucks, and can be used in boats but want to be positive it can be.
Thanks!
Thanks!
Don't forget the marine grease. As important as charging your batteries. Grease the drive shaft every hour of run time or every time you go out whichever comes first.
Retrieval system whether is a fishing poll with a tennis ball on the end (add a small treble hook about 6 inches down from the ball), a raft, a floaty, or whatever JUST DON'T SWIM FOR IT, its not worth your life.
Yes you can use that TX/RX in the boat make sure you balloon the receiver to keep it dry.
Also suggest getting it to run before you go to the lake, nothing is more frustrating than getting to the pond and have a boat that does not run. Don't run the boat out of water for more than about a minute, it requires water to cool the engine down unlike the fins on a car motor.
sorry I add a little bit more to the above post. lol
Yes you can use the same grease.
I don't know anything about that boat but do a little searching on the boat name. Check out http://www.intlwaters.com/ for more info. Headers and pipes are usually available for most motors, you should be able to find something out there for it.
I signed up for that site yesterday and I am waiting for the admin to approve my account.
same fuel as a buggy will be fine, as long as its not airplane fuel.
I would say any 20% car fuel would work.
Fuel in a boat motor I always use no less than 18%, the reason is that in a boat you are running the thing full boar 95% of the time, this will ensure the bearings will keep oil on them. Also since you are running in water temps, when properly tuned, allows you to use higher nitro content. Currently I run a 45% nitro 18% koltz 95/5 synthetic blend. Stock and Modified engines both. Noticeable out of the hole and maintaining speed in corners.
You will have to see how it runs. If its smooth on the water no need, if it slaps the water also know as porpoising, it could use some. This is of course in a straight line run. If it has a tendency to skip in turns, you would need to look into small turn fins on the sides in back.
Sweet I will see what kind of nitro the shop carries out here. I just wanted to make sure I get the right nitro for the boat.
The boat came with the turn fins and I am going to try it with and without them on. I will also watch to see how it is on the water before getting the tabs.
If it needs the tabs where can I get some adjustable ones at?
Cats don't use trim tabs, most of the adjusting is done with the strut angle. No other hardware should be necessarily for the boat, read the manual, it should have setup tips for that model. It can be found at proboatmodels.com.
I am needing a new header since the pressure fitting is stripping out.
I was looking at this header
http://www.funrcboats.com/ProductInf...ductid=MAC2043
I was also looking at this tuned pipe to get
http://www.funrcboats.com/ProductInf...ductid=MAC1110
Then I was going to drill into the pipe and put the pressure fitting into that instead of the manifold.
If there is any place to get these parts cheaper let me know!
