I need a little help......
I have a shockwave 26, I recently installed a duratrax 8t esc and a 13x2
checkpoint set up to upgrade from stock. My problem is that the boat hesitates, goes a little bit then stops?? When I take it out of the water it runs just fine with no hesitation?? Any advice would be greatly appreciated :nod: Also can anybody tell me what to upgrade my prop to with this set up and the stock set up just incase I have to reinstall it. Thanks |
Originally Posted by dimerip87gt
(Post 5843406)
checkpoint set up to upgrade from stock. My problem is that the boat hesitates, goes a little bit then stops?? When I take it out of the water it runs just fine with no hesitation?? Any advice would be greatly appreciated :nod: Also can anybody tell me what to upgrade my prop to with this set up and the stock set up just incase I have to reinstall it. Thanks 1 What kind of batteries are you using (nimh or lipo) and number of cells. 2 What system drive are you using? 3 Are you using a seperate batterypack for the electronics? 4 What prop are you using now and does it have a dogdrive? |
Originally Posted by MrUnlimited
(Post 5844673)
Ok, first some questions:
1 What kind of batteries are you using (nimh or lipo) and number of cells. 2 What system drive are you using? 3 Are you using a seperate batterypack for the electronics? 4 What prop are you using now and does it have a dogdrive? I'm not using a seperate battery pack for the electronics. Also I'm not sure on what system drive I'm using and I'm not sure what a dog drive is. Sorry I'm not to familiar with boats, at least not yet :D The prop is the stock prop, everything on the boat is stock minus the esc and motor. Thanks :cool: |
What radio are you using? :D
Stock python.
I have also heard that spektrum doesnt work that well in boats........:tire: |
(Post 5845125)
Stock python.
I'm going to try a different motor for sure.
So I should be OK using spektrum in a boat............:tire: |
You could also try stiffer springs and take a look if the brushes didn't wear out. If so replace them with new ones.
