Go Back  R/C Tech Forums > General Forums > RC Boating
Dmuas Lil' swamp buggy build >
Like Tree51Likes
Old 12-08-2023, 01:45 PM
  #46
idk about rock hard ice but snow yes.
Hoping the epoxy I clear coat the boat with will harden the 2 balsa wood pieces that make up the two outside running boards.
-d
MonkeyCmonkeyDo is online now
Old 12-08-2023, 01:47 PM
  #47
the 5min epoxy I have I don't like for the clear coating of the whole boat. I do like it for glueing together.
d
Old 12-08-2023, 02:19 PM
  #48
Bud
Definitely epoxy the motor mount and where it mounts to the boat.
MonkeyCmonkeyDo likes this.
Bud is offline
Old 12-08-2023, 04:23 PM
  #49
Its only wood glued on but will get the epoxy coating... too late.
Edit. Thought you were talking about the rudder mount bud. I will epoxy the motor mount together yes and to the deck when I measure from the prop to rudder.
-d
Bud likes this.
Old 12-09-2023, 08:36 AM
  #50
Bud
Probably not too important if you're going electric, but if it's a nitro motor the epoxy handles the vibration better.
Bud is offline
Old 12-11-2023, 10:47 PM
  #51
motors here! Esc is here! Got some practice props!
Bud likes this.
Old 12-13-2023, 07:21 AM
  #52
petersen114's Avatar
Boat’s coming along good.
petersen114 is offline
Old 12-13-2023, 08:04 PM
  #53
Ty Petersen! Wood glues done most of the work so far lol.
Rudder horn and bellow for rear where the link comes out showed up tonight.
made the rudder link and fan cowl/shroud tonight. Not sure how theyre gonna look or fit up till i get farther along.
ordering the 2 part epoxy and the 1 pool noodle tomorrow with Amazon prime so should be here in 1 or 2 days!
Gonna take the steering servo and reciever out of my xray f1 rc car since im broke rn and need the money for xmas and other expenses.
rc on all! Local dog walking park is flooding as I write this and calling my boat to the water! Gonna go all white with some red.
-d
Old 12-14-2023, 12:45 PM
  #54
I may have done this boat in. I put the bellow too close to the top and split the whole back transom.
I glued and clamped it. After the epoxy we will see.
Gonna remove the metal piece and do two coats on the inside. The outside will get 3 after the top deck is placed and flush.
d
Old 12-14-2023, 03:42 PM
  #55
Bud
You could put another transom on the inside of that one for your strength and move the aluminum thing down a bit. Then all you have to do is fill the gap at the top since you're painting it anyway. If that's the worst you ever screw up you'll be pretty lucky. You might even be able to file the aluminum flange down even with the top of the transom and not have to move it down. Solving problems is a big part of building.
Bud is offline
Old 12-14-2023, 05:15 PM
  #56
Ya I tried to sand down the flange flush with the.top deck. Gonna remove it and file it. Epoxy it in place when im done epoxy lining the inside of the boat. Gonna do that in a spare bathroom with the fan on, gloves, and mask.
guess it's pretty nasty of a smell and it's cold and damp here rn.
D
Old 12-14-2023, 07:49 PM
  #57
Bud
That's why they made a dremel.
Bud is offline
Old 12-15-2023, 01:18 PM
  #58
You know. I got one of those in the garage. Just gotta throw the sanding drum on it. Hm. Ty bud.
I usually use hand tools when I'm working. Lol.
D
Bud likes this.
Old 12-15-2023, 09:45 PM
  #59
Bud
You owe it to yourself to run that thing on ice at least once. The difference between running on ice or water is tremendous. It'll perk that little boat right up.
Bud is offline
Old 12-16-2023, 01:29 AM
  #60
Yaaaa I've already debated making some skis out of aluminum. Got the rudder and boat inside and out epoxyed. Idk if I like how it turned out. Gonna have to wait till it hardens so I can fine sand it some.
d
