Dmuas Lil' swamp buggy build
#18
finally got some glue and started this lil' buggy.
1st step. Laminate some pieces. Make opposite sides and the rear of the boat. Also a nose piece to stiffen the middle front of the hull. I think it's a hull. Lol.
glued the pieces and sat soup cans stacked on top for weight.
#20
more skeleton of the hull from this morning after I pulled it up from the paper a little and carefully.
Weight. Blahblahblah. Next i think is to sand the nose beam and shape it and add the skins along the bottom i think. Idk ill check later. Need to pack for tx and turkey day ect.
-d
#22
Home from work. Shaped the nose beam. Glue prep for the left skin of the hull. Pics of it all weighted down. Trying to remove as much gappage as possible. Shimed a spot too with excess material from the wood under one can to remove the gap in that spot.
d
d
#25
Suggestion... run a bead of glue on all the seams on the inside of the hull. A little extra strength won't hurt.
#26
Yup! As soon as I get these skins on the hull. Gonna reinforce the transoms and run beads of glue around all joints. I did get some epoxy. May try and water it down with alcohol and test it on some scrap remnants to see how it turns out and if I'll need the clear coat 2 part.
d
d
