New tx problems
So recently my old austar tx fell into the lake (dam dog ) and ruined it.so I got a new fly sky fs gt3b, nice unit but I can't get it to sync with my fly sky escs.they worked fine w old to.tried erasing memory in esc,didn't do any good,even tried setting throttle end points,no good.when I power up esc,as soon as it arms it full throttle in reverse.when I trimmed it down as far as it would go it's still about 3rd throttle in reverse.of course booklet don't tell you much.is there a way to reset memory in esc ? ( Sorry flycolor 150amp esc 2 of em )
make sure channel 2 is functioning with servo If it works with servo then it should work with esc Reprograming ess has nothing to do with problem.
Have you tried reversing the throttle switch on your transmitter?
未命名 -1 (flycolor.net) follow instructions but disconnect one motor wire.
I would think if his trim turns it down, he's linked.
The link to instructions will fix the problem.
Just curious if you'd found the problem..
