Go Back  R/C Tech Forums > General Forums > RC Boating
Speed control set up >
Old 10-12-2021, 04:57 PM
Default Speed control set up
Hi all. I have a Genesis which took on water which ruined my ESC. I have replaced the ESC and receiver. Now when I bind the receiver - Flysky FS-GR3E to my transmitter Flysky FS-GT3B the motor goes straight to full speed and will stop when I push the trigger forward. Any ideas as to how I can make it behave normally?
Thanks in advance,
Don
olderbutnowiser is offline
Old 10-12-2021, 06:16 PM
the rc guy's Avatar
what esc?. calibrate it to radio unplug 1 wire b4 turning it on
the rc guy is offline
Old 10-12-2021, 06:38 PM
Thanks for your reply. ESC is Turnigy Marine ESC 150 amp. And had the issue a bit wrong. It goes to full revs and goes to zero revs when I pull the trigger right back to the handle. What do you mean by one wire?
Old 10-13-2021, 04:16 PM
the rc guy's Avatar
1 of the 3 wires that goes into motor from esc. recalibrate esc.. and switch radio th from either fwd to rev or vise versa
Old 10-14-2021, 01:27 PM
Bud
If you have a throttle reversing switch on your transmitter, try switching it and see if that solves the problem.
Bud is offline
Old 12-06-2021, 11:45 PM
Hi, This video might be very helpful for you. Chk it
https:// youtu.be/f2Jzn9PmZGA
fridayrack is offline
