Go Back  R/C Tech Forums > General Forums > RC Boating
Brushless motor for 1400 mm double jet boat >
Old 03-22-2021, 06:51 AM
Questions?? Brushless motor for 1400 mm double jet boat
Hi, I'm new at this forum. I'm building a kind of RC rescue boat powered with 2 water jet thrusters with 40mm nozzles.
Now I have two Flycolor 120A ESC powered from 4s Zippy LiPo packs. But currently installed motors X-Team XTI-3665 2650KV get overheat when I try to tow any person.
don't need to reach great speed (it would be nice if it goes up to 40-50 km/h) but i need some motors with higher torque. I didn't see any specs about motors available on the internet sites.
The main problem is that the motor wires becomes very hot and unsolder from connectors :P
Are there any unexpensive (one of this project issues) motors i could use? What should i look for? I cant change battery (only 4 cells) or esc.
Xantus is offline
Old 03-22-2021, 08:23 AM
the rc guy's Avatar
why do you need a recue boat that goes 30mph. My recue boat will do just faster than the 7mph that my local river runs(about 12). Id drop the kv in you motors
the rc guy is offline
Old 03-22-2021, 08:45 AM
I mentioned "it would be nice to reach 40 km/h" - it's not necessary .
I think about decreasing KV but it usually means higher motor voltage, and i am afraid about torque loose then.
How much KV should it be? 2000 or less?
I noticed that these motors only overheat when towing, without load there is ok.
Xantus is offline
Old 03-22-2021, 02:09 PM
the rc guy's Avatar
if they over heat when towing only the drop kv down. 1900 should be a good amount of thrust so you can tow whatever you need,,
Old 03-22-2021, 04:00 PM
Ok, do You recomend something? Motors like SurpassHobby or similar in 36xx class with KV smaller than 2000 are officially designed for higher voltage, and there are no charts showing their voltage to torque relationship. Or i can't find them.
Maybe some of these :
Surpass Hobby 4074 2000KV with max 30V,
Surpass Hobby 3670 1850KV with max 24V,
They come with original cooling jacket, But could they work with 4s batterypacks?
Xantus is offline
Old 03-23-2021, 12:51 PM
the rc guy's Avatar
id pick this..
US SHIP SURPASS 4074 Waterproof Brushless Motor + Water Cooling Set for RC Boat | eBay
Old 03-24-2021, 02:40 AM
So this max voltage (here 30V) means I can use 4s instead of 6s battery? Neither sellers or manufacturer don't provide any info about it
Xantus is offline
Old 03-25-2021, 03:48 AM
the rc guy's Avatar
it says 26v..you can use 6 cells...you just have to scroll down a tad 60k max
Old 03-25-2021, 09:14 AM
So it will have 14.4*KV=27360 turns/min? It's enough for me
However when i was buing a motor for plane (some redox) both max and min voltage were mentioned in documentation.
So I'm ordering these 4074 2000KV motors. Very big thanks for help I'gonna put final effects here
Xantus is offline
