Props
Old 12-27-2019, 06:14 PM
Default Props
What works best on a cat 2 or 3 blade? I see the real offshore boats sport 5 blade,but that's like 5000hp or better
Zmann is offline
Old 12-28-2019, 09:11 AM
the rc guy's Avatar
I like a nice 3 blade stainless steel prop .but you better have the hp to turn that prop..unless you built your boat as in custom id stick with the stock props..they make brass bronze stainless plastic.white n black
the rc guy is offline
Old 01-06-2020, 12:57 AM
Propchecku37's Avatar
Trader Rating: 51 (100%+)
Default F
What size Cat are you running? nitro, gas or FE?
Propchecku37 is offline
Old 01-06-2020, 01:47 AM
I never played with props with my Sonicwake but I know there’s a lot to it.
its also a loaded question. It’s like hearing you either get a prop that will get you on plane quick or one that is for speed runs
If running fe I wouldn’t make agressive changes because things can get hot quick in boats. Rcgroups forums are really good for boats. I’d ask the guys there that are running the same cat as you what they’d suggest. Little changes can make a huge difference
Trlmatt is offline
Old 01-09-2020, 10:09 PM
Its a 40" elec with dual 880kv motors
Zmann is offline
Old 01-10-2020, 12:05 PM
the rc guy's Avatar
Zmann does port motor rotate ccw or cw?. same with starboard... what voltage?...
Old 01-10-2020, 05:51 PM
I run a 1/8 Scale Hydro Neu 1527 1.5y 850 kc 180+HV Esc on 8s lipo and run 54mm -57mm 2 blade or 3 blade, 1.3,1.4 pitch Chris @ Dasbota might be able to do up some props for you. He works with ABC props, and other stainless props
Old 01-13-2020, 04:30 PM
Yes they are counter rotating and I have a 6s batt for each motor & esc.would it be more practical to run both motors of one battery ? Both batts make it pretty heavy.transom is barely above water at stand still.for some reason I can't load any pics.
Zmann is offline
Old 01-13-2020, 04:50 PM
the rc guy's Avatar
Your not able to load pics till you have 10 posts..
Old 01-13-2020, 08:39 PM
you could possibly run 4 3s lipos set up, depending on room in the hull. Only running 1 lipo .on 2 motors would cut your run time in half
