Wired
Old 12-17-2019, 06:49 PM
Default Wired
Can anyone tell me how to wire up 2 motors 2 Esc. 2 batteries and 1 reciever ?
Zmann is offline
Old 12-18-2019, 04:05 AM
the rc guy's Avatar
Yes Zmann I can.. You need a Y harness ..Id make 1 b4 I buy 1.. it plugs into the receiver to run 2 servos on 1 channel or 2 escs on 1 channel .or you can if your radio has it mixer ….You will also need to pull the center wire from 1 esc so your only using 1 esc bec ...Im me I can help you more
the rc guy is offline
Old 12-18-2019, 02:11 PM
I did what you said but only one motor works.do I need a Bart for each motor? Waiting for other to charge I used 1 batt for both motors.
Zmann is offline
Old 12-18-2019, 04:01 PM
the rc guy's Avatar
zmann you will need to calibrate both escs separate then you can remove the center rx plug wire the + one in the rx plug
