Go Back  R/C Tech Forums > General Forums > RC Boating
Have 2x Spartans, looking for best simples charger for charging 4,6, or 8 3S packs >
Old 07-26-2018, 11:42 AM
regr's Avatar
Default Have 2x Spartans, looking for best simples charger for charging 4,6, or 8 3S packs
Hello, guys, I'm new to this forum, I have 2x spartans that we pylon race out on the bay in front of my Cabin at Turtle Lake in northern Saskatchewan.
I'm looking for a good charger to charge at least 4 3S packs at the same time, more would be better, even 8 at the same time, as long as they charge in a couple hours thatís fine.
I'm sick of waiting for the slow chargers to poke away for hours and hours while we miss good glass lake time.
Please let me know what you guys think, I don't know enough about these new Lipo batterys.
Reg
regr is offline
Old 07-26-2018, 11:59 AM
the rc guy's Avatar
as long as you can power 1 here enjoy.Revolectrix
the rc guy is offline
Old 07-26-2018, 12:02 PM
regr's Avatar
Hello I dont understand what you said? Sorry, I'm not experienced I'm new to Lipo batterys.
Reg
regr is offline
Old 07-26-2018, 03:30 PM
the rc guy's Avatar
High power output charger but you need 18volts dc to get the full amount of amps. readup on it theres a link follow it and read. then u might know. here is more info again read on.Electric RC info, how-tos and such - TJinTech
Old 07-26-2018, 03:43 PM
the rc guy's Avatar
in this hobby one will need to read read and keep on reading . might start a cheat sheet
Old 07-27-2018, 09:10 PM
regr's Avatar
Default Thanks i ordered a nice charger and a parallel board, will use big lead acid bat
Thanks so much I called them and talk to one of their tech guys and he was so helpful sounds like a great product and I ordered a nice charger Iím going to use to Mercedes-Benz sprinter van batteries so that I donít hurt the batteries running them to Lo and Iíll charge the four packs in two or three hours. Thank you
regr is offline
Old 07-28-2018, 10:32 AM
the rc guy's Avatar
better watch the battery (as in supply) voltage so you can crank it up or get home. better keep a A123 pac with you to help out your start. im sure you can get that charge speed up faster than 3 hours.4 batteries
Old 07-28-2018, 11:07 AM
regr's Avatar
Default revolectrix order info for Reg's boats
Thanks guys for your help. I purchased the following gear from revolectrix. I called them and talked to one of their sales engineers and he was very helpful. I'm going to charge using two 12 volt MB sprinter van batterys as I have a stack of them brand new. Any comments on if I should charge with the 12 v van batterys in parallel or serial?
1x Cellpro PowerLab 6 with EC5 input cable, 1000W, Multichemistry Battery Workstation
1x Four Port MPA Adapter Combo with an EC5 Connector and Cable for Connecting to a PowerLab Charger
12x EC5 Connectors - One set male and female
1x FUIM3 USB Interface Module for 2-way data communication
1x Cellpro PowerLab, Plier Clip Assembly, 2 ft, 60A
Last edited by regr; 07-28-2018 at 11:12 AM. Reason: spelling mistakes and layout problems
regr is offline
Old 07-28-2018, 12:03 PM
the rc guy's Avatar
if it was me id run the 2-12 v batts in series. so you get near 26.5 volts. so these are stand alone batteries not in the van listed correct..without being deepcycle batteries id give you less than a dozen charges off them b4 there done.
Old 07-28-2018, 12:38 PM
regr's Avatar
Hello, ok, I was not sure I guess with 4 packs hooked up to the board, it would be better to have 24 volts rather than just 12, makes sense . Do you guys like the charger I purchased, anyone use one or have the manual for one in PDF format as I won't get it until Aug 7 or so, would like to read up on it.
Reg
regr is offline
Old 07-28-2018, 01:38 PM
the rc guy's Avatar
its ok im the only 1 helping.. manual here. its I the cellpro spec or files area.Revolectrix
Old 07-28-2018, 07:54 PM
regr's Avatar
Thank you RC Guy!
Reg
regr is offline
Old 07-29-2018, 12:29 PM
the rc guy's Avatar
np
