Tekin RS pro black edition thread
#49
#50
Ok I am confused....................the motor limit says 36mm can 2 pole motor that's all it says for 2s brushless..............a Maclan 7.5 turn motor is a 2 pole 36mm can but from what others have said on here I would not want the RS Pro BE for this motor?????????
#52
I have been experiencing higher than normal esc temps in my stock B6. I am wondering if my cap is dead. Could I have damaged the cap while soldering on the battery wire leads?
Keep hearing that other guys RS Pros BEs are like 120-140 with a motor fan.
Setup
B6
RS Pro BE (Blinky)
Spec R 17.5 (72/26 48* Timing)
WTF motor fan plugged into Sanwa
Receiver
Motor Temp: 100
ESC Temp: 170 (140 without motor fan)
Thanks!
Setup
B6
RS Pro BE (Blinky)
Receiver
Motor Temp: 100
Thanks!
#53
Hopefully Randy sees this! He asked what type of videos we would like to see on FB. I recommend “how to tell when your Cap is not working like it should “
That would be great as I am often wondering if it’s working as it should. And when it’s starting to deteriorate or a bad connection how will I know
#54
I would like to see a video on that as well.
#55
Need some help! I accidentally plug in the wrong battery connector and spark and burning smell out from my esc. Is there anyway to save it or I have to get a new one? Thanks
#57
Setup
B6
RS Pro BE (Blinky)
Receiver
Motor Temp: 100
Thanks!
Setup
B6
RS Pro BE (Blinky)
Receiver
Motor Temp: 100
Thanks!
If the cap is bad however, you would see higher ESC temps.
#58
#59
Touch your ESC's battery leads together(WITHOUT THE BATTERY CONNECTED!) and you can discharge the cap, for 90 seconds. Then reconnect the battery, you should hear the snap.
#60
Hi all , having issues atm with my rs Pro black and my Hotwire 2.0 255 connecting using normal mode that allows me to apply and save settings. Each time I hook it up it will only run demo mode. Thanks for any help and info
