-   -   Tighter fitting 5mm bullets? (https://www.rctech.net/forum/radio-electronics/998706-tighter-fitting-5mm-bullets.html)
Bri 09-25-2017 07:19 AM
I have a Lipo battery with 5mm sockets and the included 5mm bullets are on the loose side. Any way to tighten them up or anyone know of some 5mm bullets that fit tighter?
Best regards,
Brian
Andy Koback 09-25-2017 07:59 AM
Best regards,
Brian
A good bullet will have an "X" in each end so all you have to do is take a Exacto and insert it in the slot and spread them apart a little bit. Squirrel cage ones are junk!
CCristo 09-25-2017 07:05 PM
I know some people don't like the bird cage style bullets, but I've never had an issue with them in 2wd & 4wd mod buggy. The ones I use are the Reedy Low Profile. If you insist on the non cage style then check out the SMC adjustable bullets.
+ http://www.youtube.com/watch?v=RK26H1A_QNE" title="View this video at YouTube in a new window or tab" target="_blank">YouTube Video
http://www.youtube.com/watch?v=RK26H1A_QNE"> http://www.youtube.com/watch?v=RK26H1A_QNE" /> ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Rebuke 09-25-2017 08:09 PM
If my bullets start to get loose I'll stab a toothpick down the center and cut them off with flush cutters.
anthonyscardina 09-26-2017 06:22 AM
I usually push a small phillips driver into the bottom to open them up.
savage24x 09-27-2017 04:24 PM
MACLAN MAX CURRENT 5MM GOLD BULLET CONNECTORS
Maclan Racing ACCESSORIES
Work well for my packs.
Scott R 09-28-2017 11:45 AM
strip a 1/4" or so length of insulation off 1 conductor of an old servo wire, insert it in the center of the 4 parts of the connector
