Updated 2017 Lipo Battery Charger Thread
I've been pondering a new charger as well. Currently semi-decided on an Ultra Power UP200 since it'd be nice to be able to charge two batteries at once but can't really justify anything very expensive, and it seems to be a reliable enough charger.
Internal power supply is kinda convenient since there's less of a hassle when transporting it, I think. Downside is that many chargers give twice as much power with an external supply as compared to to the internal one. For example the UP200 or a SkyRC D100 give 2x100W with DC a power supply, but with the internal AC power supply it only gives 100W total. Having the extra power would be nice, but I don't really know what'd be a reliable power supply + charger combo for at least two batteries at a reasonable price (under $100 basically), or if such a thing even exist at that price.
For 2S the answer is: no, you do not need 1000W. 8.4V x 40A = 336W, adding in the inefficiencies and all that, 400-450W would be all you ever needed - less, if you charge at less than 40A. Chargers like the iCharger 406 Duo have such high Watt numbers to do 6S at 40A (so 25,2V x 40A = 1008W). So, as you can see: how many Watts you need, is entirely determined at what current you want to charge your 2S batteries. For 5A (8,4V x 5A = 42W) something with around 50W is enough (always remember though: there is no 100% efficiency, so a couple more Watts cannot hurt).
AC chargers usually only have a rather limited internal power supply, so that's why all the high powered ones come as DC - you just need a beefy power supply for them to max them out. External power supplies can also be used for pit lights, tire warmers (in On-Road), etc. - but it's another box you got to bring every time. Again: personal decision.
IMO, if you buy a new, quality LiPo nowadays, you don't need to stick with 1C anymore. Personally I now use 2C now pretty much all the time - never needed more than that yet. But that's personal preference, just like the 40A charging that some people do. It's your battery (and your car or even your house), not anyone else's, so be aware of the risks and decide accordingly.
I recommend a charger with a built in AC power supply. And I recommend 200W minimum.
The expensive part of a charger is the power supply. This is why DC only chargers are a lot cheaper, and it is also why most AC chargers don't have much power....to keep the price down.
A DC only charger is only as good as your power supply, and the power supply is a significant expense. A 1000W DC charger hooked to a 200W power supply becomes a 200W charger.
In the case of the biggest iCharger, you actually need TWO of their power supplies to give you the full rated output! The cost? $540 (two power supplies) + $350 (icharger) = $890!
The affordable option would be to go to hobbypartz.com and get one of their chargers with built in AC power. The one I own is 200W on 1 channel. This charger allows me to rapidly charge a single pack, or I can parallel charge several packs.
I don't like most multiple channel chargers because they limit you to a 1C charge rate per channel. So you can't quickly charge a battery.
This year I bought the EV Peak SD1 from Amain.com. It is a 2 channel AC/DC charger. It charges at 300W/channel on AC (500w/channel in DC). I use it exclusively on AC, and it has all the power I ever need for charging 6S packs.
I've been racing for about 25 years and started on Tekin chargers (Now that's dating myself). I have run everything from the expensive competition electronics chargers to the Orion Touch, LRP, etc. I have used AC/DC and DC only chargers. I currently run the icharger 4010 duo and a server power supply I found on ebay for $60 (type rc power supply in to the search engine on ebay. RL has 75 amp supplies).
If I had to recommend something to someone it would be the icharger 406 duo (about $280) and the RL power supply. I bought the 4010 duo instead of the 406 because I got it for the same price. The 406 duo with that power supply will easily charge 2, 2s lipos at 40 amps each. I am not here to talk about the higher charging rates and benefits/drawbacks, just that this setup can do it. I recommend this because there isn't anything this combo can't do. This charger has multiple car memory and cycle features, which will suit any demand you have. It's about $360 or so (look in the for sale section on here and maybe score a deal) but this combo really is the best when it comes to features, albeit doesn't have a touch screen. I shy away from AC/DC chargers because one half of that system can go down and you're done. In the past, any issues I've had with those chargers was the power supply going bad. Having a separate power supply may help you in the future. Plus I also rigged up a USB charger to plug in to my power supply to charge my phone and such at the track.
Another feature of the icharger is its ability to do regenerative charging and discharging. This allows you to plug in a discharger and discharge your batteries at higher rates, which is something hardcore spec class racers do. I use that feature and the storage setting to get my lipos to a safe storage voltage faster. With a 5 or 10 amp discharge rate on most other chargers, this takes a while. Another benefit of having higher charge rates is when you aren't paying attention and forget to charge your batteries. Dumping 40 amps in to a battery will get it charged pretty quickly.
I want a charger can do 4 at onces
I have this
"The Neutrino Ticket" 350W Combo - ProgressiveRC
Works great and will charge a 2s battery in 10-12 mins. A 4s in 15-19 mins. Small inexpensive and high quality.
The 308 can only charge up to 30 amps. The numbering of the chargers has meaning. For instance: the 406 can charge 6s batteries at up to 40 amps wheres the 4010 can do 10s up to 40 amps. I understand you say you don't charge at higher amps but I would say get the 406 for the piece of mind that you should never need another charger.
For a good DC charger get the Revolectrix GT1000DUO, that has all the power ([email protected] per channel) and precision you need with two channels. It's a steal now at 135$.
I have (2) of the Elan R chargers and love them. Only one output but does 15a on in internal power supply. @ yrs. and running with no issues. Also has the USB port for charging purposes too. Can also be run on an external power supply IF the internal one would fail so it's still usable. They also offer a dual output model as well.
