Radiolink RC4GS only for ESC ? >
Old 09-10-2017, 08:22 AM
Default Radiolink RC4GS only for ESC ?
Hi,does anybody know if this radio works only with electric motors? Because there is no battery connection on the receiver,only throttle,steering and aux 1 & 2. throttle,steering (rudder) and aux 1&2.
There should be a way,i guess but which?
-Photos from the user's manual.
Attached Thumbnails Radiolink RC4GS only for ESC ?-image-23.jpg   Radiolink RC4GS only for ESC ?-image-24.jpg
LYBCO is offline
Old 09-10-2017, 08:51 AM
sacmiata's Avatar
Trader Rating: 27 (100%+)
Just plug in the battery to channel 3 or 4. Ran a few nitro cars with the older version of this radio like that.
sacmiata is offline
Old 09-10-2017, 08:58 AM
Thank you very much!!!
LYBCO is offline
Old 09-11-2017, 05:33 AM
Trader Rating: 33 (97%+)
If you plan to use the Gyro, then be sure not to plug anything into the respective channel that the Gyro is configured when active, I think Ch3 is default... I blew out a port on one of my Rx's when I tried using an external fan while shared on the same port. The Rx still worked for Ch1-2 and Ch4, but Ch3 was dead... I was able to switch the Gyro to work on Ch4 and powered my fan off a Y-harness from Ch2.
If you want to play it safe, then you can disable the Gyro completely... or use a Y-harness to supply power into Ch1 or Ch2 if you wish to continue using the Gyro.
billdelong is offline
